Old 30th September 2010, 23:02   #1
garry.brant's Avatar
Thanked: 22 Times
Default Water getting inside the front Door.....
Hi team,
I have a Hyndai accent 2009 model and i did have a complaint within first 4 months that right side front speaker was not functioning. I took it to a local accessories shop and when he checked he found that there was water inside the front door and speaker was all wet . He used a dryer and refitted the speaker and it was all working fine. Now after 8 months i am facing the same issue , this time when we checked it was found that the speaker has gone for a tose due to humidity and water .
Could you please suggest how this problem can be fixed or should i stop using front speakers.
garry.brant is offline   Reply With Quote
Old 30th September 2010, 23:09   #2
jatinpatel's Avatar
Thanked: 191 Times
If you observe the under side or your door or the lower corners of the hall there must be slots or holes provided by manufacturer to drain the water as when it enters the doors.
If the slots are clogged then they wont allow the water to go out hence it will start accumulating inside the door which will results into your problem.
Just simply de-clogg the holes your problem should be solved.
jatinpatel is offline   Reply With Quote
Old 1st October 2010, 00:02   #3
Thanked: 660 Times
Also check the window garnish, If its wornout or uneven replace it.
Hydrostatic Lock - Water inside the engine falcon Technical Stuff 27 30th August 2017 20:54
Help!Water getting inside car sans33 Technical Stuff 34 21st September 2015 12:02
Honda City door lock from inside mm403 The Indian Car Scene 5 15th February 2012 02:20
Fabia Central Door Locking - No way to lock the doors manually from inside the car kunaalsaigal Technical Stuff 11 22nd December 2010 12:49
