| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #2 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
Shan2nu
__________________ VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE | |
| | #4 (permalink) | |
You'll need massive amount of torque or least amount of tyre grip, to spin the wheels in 2nd and 3rd for a longer time. Next time, try it on a slushy surface, you'l spin the wheels for a longer time. Shan2nu
| | #6 (permalink) | |
In simple, it's your torque figure multiplied by the gear ratio and final drive ratio. If a car produces peak torque of 200nm at 4000 rpm and the 1st gear has a 3.4:1 ratio with your final drive being 4:1. At 4000rpm in 1st gear, the torque reaching the wheels should technically be 200 * 4 * 3.4 = 2720nm but, it usually ends up being a bit less due to loss of power through mechanical friction. So, if you have to achieve the same result in 2nd gear with a ratio of 2.5:1. the engine will have to produce 272nm at the crank (which isn't possible as the engine torque peaks out at 200nm). What results you achieve in 1st gear can never be matched by the others. Shan2nu
__________________ VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE Last edited by Shan2nu : 4th December 2005 at 00:11. | |
| | #8 (permalink) | |
| Senior - BHPian | Quote:
Just wanted to know how its done and whats the difference..Anyways i think i'll stick to 1st gear wheelspins right now ![]()
__________________ Driving around... ON BOOST!!!!!!! | |
| | #10 (permalink) |
| BHPian Join Date: Jun 2005 Location: Mumbai
| Guys is it possible to change gears just when we see that the wheelspin in the 1st cant be held any longer.. For eg. while doing a burnout on a bike we can use half clutch to move to second gear n continue. Hell we can even drop the gear without the clutch. Anything possible for cars ??!!?? |
| | #14 (permalink) | |
hey shan2nu could you please elaborate on that as this is an interesting topic.firstly what do the terms slipping clucth and damaged drive shaft mean. rev
__________________ Revin Beyond Limits !! | |
| | #15 (permalink) | |
Driveshafts can get damaged if they are subject to sudden jolts of turning force (torque). It's ok if the wheels start spinning easily but, if they don't you could damage them. Even if they don't get damaged, they will encouter "Play" in the long run. Tyres are bound to get worn out due to the friction caused when they're scraped against the road surface. Engine life is reduced as it has to revv close to the redline without the required cooling aid. When a engine is revved with the car in motion, the air hitting the radiator helps cool the engine but, in this case, the car is basically stationary. All the cooling comes from the radiator fan (which isn't sufficient). Shan2nu
__________________ VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE Last edited by Shan2nu : 5th December 2005 at 00:43. | |
| Thread Tools | |
Similar Threads | ||||
| Wheelspins, 180s & 360s - and how they affect your car | tsreekaranrao | Technical Stuff | 30 | 13th February 2006 18:29 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
Why would you want to do a wheelspin in 2nd or 3rd gear. Who are you trying to impress.
