Old 6th October 2010, 11:23   #1
Default 2004 Honda City Gxi AC Problem
I was wondering if anyone has experienced this problem. The AC stops cooling sometimes midway during a drive. Maybe when the temperature goes up. I'm best trying to describe what my mother told as this is not my car and dont use it.
The mechanic I gave it to told me the compressor, fan motor and extension valve needs to be replaced and it will cost 28,000 including parts & labour.
I drove the car last night for 45 minutes and the cooling seemed to be A Ok. I feel since it is an intermittent problem it shouldn't require complete replacement of these parts.
Can anyone offer their advice or contacts of a good AC mechanic in south Mumbai who I can show it to?
Sid
SidMeer is offline   Reply With Quote
Old 6th October 2010, 11:32   #2
Jaggu's Avatar
Thanked: 8,693 Times
First thing is check the ac gas level, if its optimum.
Next, check if the AC stops cooling after a slightly longer usage, if so switch off only the compressor button for 5 minutes and switch ON again. If the cooling is back to normal, then its the gas icing up which is causing this. To fix this first ensure that the inside grills are clean.
I would suggest taking a second opinion/going to a reliable specialist.
Old 6th October 2010, 11:32   #3
Thanked: 28 Times
Sent you a PM check it out.
kavesh55 is offline   Reply With Quote
Old 6th October 2010, 14:22   #4
Hashim's Avatar
Thanked: 32 Times
What it looks to me is weak compressor which is not able to handle day time heat and hence almost no cooling at day time while it will cool ok at night. Get the compressor checked at another AC mechanic for fair opinion.
Hashim is offline   Reply With Quote
New NHC ZX GXi or used 2004 Skoda rider TDI? Sri_009 Sedans 10 17th April 2006 17:43
Help me choose between Accent CRDi and Honda City GXi/VTEC vravish Sedans 15 22nd February 2006 01:04
ford fiesta tdci or honda city zx gxi dadudeonfire The Indian Car Scene 43 20th November 2005 12:35
New Honda City Gxi Montoya Long-Term Ownership Reviews 8 16th June 2005 13:39
Honda City GXI or Baleno VXI ashtrix Sedans 26 6th January 2005 16:52
