Old 27th September 2016, 09:09   #16
rajeev k's Avatar
Thanked: 1,749 Times
Default Re: 99 Santro : loud khad khad noise from front wheels.
Yes. The drive shafts need replacement. If you want to keep the car for long replacement, rather than repairs, is the best option.
rajeev k is offline   (1) Thanks Reply With Quote
Old 27th September 2016, 09:31   #17
Thanked: 100 Times
Thanks Vijay and Rajeev!
After searching on the net, I thought this sound was because of CV joints. But not sure if I can replace/repair the CV joint instead of replacing whole drive shaft for Santro.
This video shows exactly how it sounds in my case:
But I am curious how this sound started overnight? Just a couple of days back, there was absolutely no sound from this driveshaft (or the CV joints), and suddenly it started so loudly, like overnight?
Also, how much it should cost if I wanted to replace the driveshaft? If replacing only CV joints is possible, how much damage to the pocket should I expect?
Thanks!
pkulkarni.2106 is offline   Reply With Quote
Old 29th September 2016, 09:48   #18
Thanked: 100 Times
Today talked to a mechanic near my home (this one is famous for Maruti Suzuki vehicles, though he repairs other brands as well). This guy suggested replacing the Axle (drive shaft) itself. When asked if we can replace only the CV joints, he insisted not doing so because replacing the complete driveshaft is more reliable.
Although I didn't drop the car for repairs right away, he quoted around 2K for each driveshaft (I suspect both have gone bad, as I get noise when turning in either direction). Note that this pricing is for aftermarket parts and not genuine. Genuine parts would be much more costlier than these.
Please let me know if the pricing is OK.
Thanks!
Old 3rd October 2016, 11:31   #19
Thanked: 100 Times
Yeah.. replaced the left side drive shaft from road-side garage. Total cost=2K including labour. Now, the noise is gone and the car runs fine as before.
Thank you guys for your suggestions!
pkulkarni.2106 is offline   (1) Thanks Reply With Quote
Loud Noise from Hero Honda Hunk engine at 40,000 kms ashwin.terminat Motorbikes 17 15th September 2015 17:30
Ford Ikon Flair Making loud Noise (Fan/Engine). snaronikar Technical Stuff 15 10th February 2015 23:31
Loud noise and vibration with A/C on Maruti Ritz cs_rajesh Technical Stuff 20 1st May 2013 23:32
Jarring noise front brand new left front speaker skrules In-Car Entertainment 13 26th December 2011 10:53
Loud grinding noise from the rear reignofchaos Technical Stuff 19 26th March 2009 16:14
