Old 27th February 2006, 23:31   #16
adit1329's Avatar
there are a lot of factors that go into tire pressure..
like style of driving, number of people your car usually carries, the kind of roads, whether diesel/ petrol.
usually if your car carries only 2 passengers, use a slightly more air pressure on the front as this compensates for the engine weight. this gives better handling and good road grip. yes this does result in a very slight drop in mileage...
if you use more air pressure, the surface area for the tire reduces and results in stiffer rides and bad handling...
adit1329 is offline   Reply With Quote
A/C and fuel economy & How to use aircon optimally. Lukeskywalker Technical Stuff 115 15th June 2014 12:09
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
Alto Fuel Economy Woes ScarySkulls Technical Stuff 261 16th March 2013 13:21
Does Weather Affect Fuel Economy wolfinstein Technical Stuff 34 20th August 2009 00:57
Electronic ways of IMPROVING fuel economy Godfather Technical Stuff 8 1st October 2006 08:50
