Old 10th October 2010, 19:04   #1
ghatotkatch's Avatar
Thanked: 95 Times
Unhappy PICS : Car scrubbed by vandals. Will polishing help?
Today afternoon, while having a casual look at the car after parking, to my horror, I found some massive and deliberate scrubbing done on the bonnet and front sides. The shine of the car has totally gone and it's looking very ugly. I have attached the pics below.
Some maniac had his day of fun(!) at my expense, it seems. But this being my first car, that too bought only recently without borrowing a single penny from my parents or anybody else, I am emotionally quite attached to her, and am feeling like somebody has scrubbed my heart. Havent been able to get it out of my head since then. So thought of putting a query to you guys - what you would have done in such a case? will car polishing work? or will I have to go for a paint job?
The car is a 2008 model, and the paint was quite fresh on this 2year old beauty, when I got her couple of months back. Suddenly because of this defacing it's looking ugly, to say the least.
Also, does teflon (or any other) coating help prevent such deliberate scrubbing incidents?
I tried searching briefly, but didnt come across a deliberate scrubbing thread here. Hence this new one.
Looking forward to your help. Thanks in advance.
PICS : Car scrubbed by vandals. Will polishing help?-left.jpg
PICS : Car scrubbed by vandals. Will polishing help?-right.jpg
ghatotkatch is offline   Reply With Quote
Old 10th October 2010, 19:30   #2
tanwaramit's Avatar
Thanked: 387 Times
Thats really sad to see, some maniac doing such an intended scrubbing.
You may try scratch remover and polishing which may help tone down the glare of this to some level, however there seems to be no other alternative than get it repainted.
It seems its impact is on front bonnet and right side fender, so try claiming insurance on it as well.
tanwaramit is offline   Reply With Quote
Old 10th October 2010, 19:38   #3
MutantX's Avatar
Thanked: 89 Times
I would suggest you getting it repainted. Please check with the local garage for the cost of repaint.
IMO, getting a buffing or the so called teflon coating wouldnt help the cause.
MutantX is offline   Reply With Quote
Old 10th October 2010, 19:44   #4
Awaiting Email Confirmation
Thanked: 66 Times
I have been a victim of scrubbing multiple times on all my cars. It is very painful to see some (stupid person) damage your car for fun. Now i just try to keep a watch on my car wherever i am and i keep pressing the lock button on remote periodically to flash the blinkers, hoping it will scare the (stupid person).
Akki_5 is offline   Reply With Quote
Old 10th October 2010, 19:49   #5
Rudra Sen's Avatar
Thanked: 4,295 Times
Mods note: Thread moved to right section.
You have only one choice and that is painting the bonnet and the fender. I wouldn't suggest for insurance claim as you'll lose your NCB for a small job like this.
Try to park your car in place from where you can actually keep an eye. This looks like a sadist's job.
Old 10th October 2010, 20:15   #6
Ripper's Avatar
Thanked: 21 Times
I guess its repairable. Had similar scratches on my car too (black lancer) difference being that my watchman used a cloth which had a lot of rough mud like particles. I got the car polished from a painter who used a 1000 grit paper to sand the entire body and later used rubbing compound followed by wax polish. I was charged something around 800 bux for the job. Try getting this done once before considering a paintjob, would save you some cash.
Ripper is offline   Reply With Quote
Old 10th October 2010, 20:22   #7
sagarpadaki's Avatar
Thanked: 1,337 Times
Holy smokes,that's bad.really bad.I know how much it pains to see some jerk scratch up your car for fun.The best bet would be to repaint it since you cannot get back the original finish by polishing or coating.Also i can see the white underside,which means that you have lost the paint in those places along with the clear coat.
To reduce the damage,use Formula 1 scratch out.Its a mild rubbing compound available at super markets and auto accessories shop.Apply it as mentioned for 3-4 times allowing 2 hours gap in between for it to cure.Make sure you wash and dry the surface before you do this.
This method will only help you reduce the visual damage to some extent .And moreover since your car is black the scratches stand out even more.
Old 10th October 2010, 20:43   #8
Thanked: 40 Times
Dont think twice about anything. Just get the bonnet and the fender painted.
Dont waste time and money in rubbing and waxing. These hardly helps. You never get the finish like repaint & waxed. These are only consolation jobs, nothing more.
By the way, where do you park your car ?
nandans2005 is offline   Reply With Quote
Old 10th October 2010, 20:43   #9
Rudra Sen's Avatar
Originally Posted by Ripper View Post
..Try getting this done once before considering a paintjob, would save you some cash.
Don't think this process is going to help. white surface can be seen here and there. In your case it was fine scratches from sand and dust. This is a case of vandalism.
Old 10th October 2010, 21:05   #10
jp2u's Avatar
Thanked: 16 Times
To my knowledge the waxing, polishing or coating will not give you permanent solution, this looks like a work of pure Car Vandalism. Get you bonnet repainted, claim on insurance.
Invest in a car cover
jp2u is offline   Reply With Quote
Old 10th October 2010, 21:16   #11
Thanked: 66 Times
Just try this before repainting. Buy rubbing compound ( Rs 40/-only). After cleaning the bonnet, apply it with a soft cloth and then rub in round about motions. If the scratches fade away, polish the surface with wax polish. If the scratches remain, well, you have to repaint, but trying is worthwhile since the cost for the same is nominal.
Ashley Nair is offline   Reply With Quote
Old 10th October 2010, 21:18   #12
bblost's Avatar
Thanked: 6,980 Times
Its a Black Palio 1.6.
This is when you get it painted in some super cool racing design.
After all this is a car that can really carry them off.
As for the low life who did this to the car, may he/she rot in the darkest and hottest corner of hell.
Old 10th October 2010, 21:19   #13
Thanked: 45 Times
no other way, dont try to wax or teflon coat or touch up job, just paint an coat, its only solution. sorry me too an victim of those act, but with slight damage.
rajivanoj is offline   Reply With Quote
Old 10th October 2010, 21:23   #14
Thanked: 95 Times
i think I will probably need a security kit which will start blowing a siren when somebody touches my car. Wonder whether Autocop/similar has something that will cater to this requirement.
I stay on the first floor, and I park my car such that I can see it from my wide window. This was probably done during night, and I only came to know in the afternoon after parking the car in an open space in daylight.
I did try calling some autocare/car-care shops (listed in sulekha and google) frantically after I saw this scrubbing, but probably because of sunday, all of them were unreachable.
About repainting, few queries -
1. Any rough idea, how much will it cost me to repaint the bonnet and both the fenders? the scrubbing is on both the fenders.
2. any recommendations for shops/garages in Pune? or only Pandit/BUB will have a matching colour??
3. after repainting, is there any chance that the bonnet and fenders will stand-out from rest of the car?
precisely. i was thinking of launching a police complaint. but since i am not sure who could have possibly done this, i am hesitating in order to avoid any additional headache from police.
Old 10th October 2010, 22:40   #15
Thanked: 712 Times
Could this be caused by some animal tyring to climb on car from front side on bonnet or by sides. Humans trying to scratch would typically scratch in circles or long lines from some point till end of surface; don't think anyone would create small lines very close to each other unless someone is really sadist.
1. No idea about cost, but cost at TASS would be different(more) than outside.
2. Check with Tune-up plus on baner road, search for thread 'accessories shops in pune' to know about them.
3. No, painted parts will not stand out if colour code has been matched.
Don't bother them, they would be least interested in even registering a case.
sukiwa is offline   Reply With Quote
Car Wash, Polishing & more - Shell Car Care (Sec-34, Noida) Grr7 Delhi NCR 7 5th July 2016 19:22
Basic Car wash & Polishing - Vent Car wash (Tharamani, Chennai) scopriobharath Chennai 9 10th February 2015 16:59
Standalone CCTV for Cars : To catch vandals redhanded rahul4321 Modifications & Accessories 6 4th January 2015 14:13
Car Polishing & Waxing - Sparkle Car Spa (Bangalore) nitinbose Bangalore 12 19th February 2014 17:29
Polishing the car/bike. v12 Technical Stuff 46 30th October 2010 21:00
