Old 29th March 2007, 20:26   #46
vivekiny2k's Avatar
Thanked: 184 Times
just one clarification from my own observation. it happens in winters because we tend to wear lots of warm clothes, mostly fur (wool or otherwise). If you don't wear those, there are less chances of getting a shock even if it's winter.
I hate those, so irritating, at one time i had to start using my elbow to close the door. one of my friends in NY had a big beary fur coat and she used to give static shock to everybody all the time.
vivekiny2k is offline   Reply With Quote
Old 29th March 2007, 20:51   #47
wolfinstein's Avatar
I always get static jolts during winters and occasionally during summer nights, The best way is that I open doors wide and then Step out, Touch the car body with my backside.
When the space is limited and cannot open doors wide, I just touch the road or ground when I park.
wolfinstein is offline   Reply With Quote
Old 30th March 2007, 00:48   #48
SLK
SLK's Avatar
Thanked: 192 Times
its actually funny.... we all know that the shock would be minor and won't even hurt a bit. BUT still we take so much care not to touch our doors or other metal parts.
I for one have now got a permanent habit of pushing on the window glass.
But again probably thats why they call it a shock!.... no matter how small/ or expected its always a SHOCK!!
SLK is offline   Reply With Quote
Old 30th March 2007, 13:53   #49
benbsb29's Avatar
Thanked: 4,277 Times
I used to get these shocks a lot when i was wokring at my previous company. Happened when i used to touch the metal parts of the cubicle.
I thought maybe it was some force telling me it was finally time to move on to a new company... LOL ..!!
Old 30th March 2007, 13:59   #50
navdeep's Avatar
I will take this as my inspiration ..
navdeep is offline   Reply With Quote
Old 30th March 2007, 17:00   #51
bikefreak's Avatar
Thanked: 66 Times
I've been getting this for years, so much so, that sometimes visible and audible sparks jump from my neck to the corner of the car door if I pass too close to it, even without touching it !!
Yes the rubber sole does make it worse, as do dry hair and cold weather.
Some guys have mentioned that they experience it only in some cars and not in others.
The possible explanation is the upholstery. If the seat cover is cotton or leather, less static is developed as compared to synthetic covers or stock seats in many cars.
The cover of the steering wheel (if any), over which you frequently glide your hand also contributes. I presume a pure leather steering wheel cover will decrease the incidence of static.
bikefreak is offline   Reply With Quote
Old 30th March 2007, 19:28   #52
vivekiny2k's Avatar
Thanked: 184 Times
so you prefer the shock on your back side?
Old 30th March 2007, 20:37   #53
Thanked: 44 Times
I used to get this on my earlier Ford. This had fabric seats, and the act of sliding your butt off the seat generates static electricity.
Finally I made a habit of first touching the metal part of the door and holding on to it before sliding out of the car
filcord is online now   Reply With Quote
Old 30th March 2007, 20:49   #54
Ya..! Lol
Usually the intensity of the static discharge in my case is pretty high, Not only does it make itself audiable but also a proper " Chat " wala Blue spark is visible..!
Old 30th March 2007, 21:09   #55
elf
elf's Avatar
Thanked: 9 Times
I'm thinking maybe we should plug you monkeys into the National Power Grid, since it seems that we're running out of electricty these days.
Psst! Wanna make a quick buck?
I'll feed you, clothe you (in nylon only) AND give you 25 bucks a day during this summer.
Gotta coupla 3 ton air-conditioners, some fans, a water pressure booster & a microwave I'd like to run off of you.
elf is offline   Reply With Quote
Old 30th March 2007, 21:42   #56
DRC
DRC's Avatar
Thanked: 48 Times
Static charge is a common problem in dry and cold areas/season.
I have a sofa in my house which gets heavily charged and gives a severe jolt.
In a car the problem is more if you have a fabic seats, with leather the problem is less.
It was painful when I was in California. Solution I found was to wear antistatic footwear. My company used to pay for such shoes. But they never looked good ;-(
Another solution is to get down from the car while holding the metal frame of the door not the plastic door handle. Sounds counter-intuitive, but works (technically same as using keys)
DRC is offline   Reply With Quote
Old 30th March 2007, 22:43   #57
binz's Avatar
Thanked: 412 Times
Saw this on Opera.This static thing started a fire at a petrol bunk.IT happens when your clother rub against the seat;especially synthetic stuff.
Old 31st March 2007, 17:54   #58
yeah read an article about that too. Its more for the developed markets, where one has to fill fuel by themselves (no attendant!). People step out of the car carrying tons of static charge and while filling fuel t- fuel vapors are emitted in good quantity. Many a times, the static charge fires off and bang! fuel catches fire.
Scary thought. Thank god we havent reached the stage where we have to fill our own fuel.
srikantans04 is offline   Reply With Quote
Old 31st March 2007, 18:10   #59
Static devlop when the Seats have synthetic upholstery and clothes rub against the upholstery. The discharges whenever our body touches any other medium with a lower Potential . You can also experience this Phenomena when you sit on PVC moulded chairs
arun_moorthy is offline   Reply With Quote
Old 1st April 2007, 09:56   #60
angelfire's Avatar
Hey just a thought guys...Wht if the ground wire of the battery terminal is upgraded to thick wire nd also if a second ground point is made to the body..Will this help in discharging static electricity??
angelfire is offline   Reply With Quote
a shock absorber that generates electricity! greenhorn Shifting gears 8 13th February 2009 22:24
Start battery dead cars without jumper cables using static electricity revvedup Technical Stuff 23 25th February 2007 00:13
