Old 10th May 2011, 20:11   #91
Soccerfan's Avatar
Thanked: 54 Times
Default Re: Fiat to fix faulty AC in the linea and punto, entire HVAC system redesigned
Originally Posted by vivekshukla View Post
So, moral of the story - Fiat will not only make you fall in love will their cars but also make you semi automobile engineer!
. Agree with this. This T.A.S.S guys are the most careless guys i have ever seen in my life. Every time they will disconnect something in my car during service. FIAT needs to move off from these guys
Soccerfan is offline   Reply With Quote
Old 15th June 2011, 21:24   #92
GTX007's Avatar
Unhappy Re: Fiat to fix faulty AC in the linea and punto, entire HVAC system redesigned
Please help! My Linea's AC has suddenly stopped working. Blower and all the adjustments relating to ACC is working perfectly fine. But there is no cooling. Usually when I switch on the AC I used to here a clicking noise from the bonnet. But now its not there. Also the engine fan is not working. I checked it today and found that even if I keep the car idling for more than 5 minutes with AC on the engine fan does not start. I had gone for the AC up gradation in March after receiving SMS from Fiat about the same. After that the AC was cooling very effectively. But now I don't know whats wrong. Please shed some light on this issue. They had changed the engine fan during the AC upgrade.
GTX007 is offline   Reply With Quote
Old 16th June 2011, 12:13   #93
hemanth.anand's Avatar
Thanked: 5,913 Times
http://www.team-bhp.com/forum/test-d...ml#post2393564 (Fiat Linea - 2nd Birthday !!!)
@GTX007,
Check the above link, your problem seems similar to this.
hemanth.anand is offline   Reply With Quote
Old 26th November 2012, 17:02   #94
srikanthpotluri's Avatar
Thanked: 19 Times
Originally Posted by getsriram View Post
Hello friends, One of my friend has got a Linea Petrol Emotion PK. He got AC retro-fitment done in his car recently at TAFE Motors, Chennai. After the AC retrofitting, AC seems to be cooler but the noise from the AC fan is very loud.. It sounds like a big motor running when the AC is ON! He took it to the dealer again but was told that the AC Fan is bigger and this loud noise is prevalent in all the cars in which retro-fitment was done. Also, a humming noise is heard inside the cabin when the AC fan is on. Have any of you experienced the same issue? Is it true that the noise outside has become noticeably louder?
Hi - I had given my Punto Emotion+ which has run 54000 KMS today for service at Concorde Sanathnagar, Hyderabad. The same issue as above i was having from last 3-4 weeks. Just now the SE called and said the fan needs to be replaced and it would cost around 10K .
He said that most probably the issue would be due to bearings wearing out, but he isn't sure.
I had asked him to fix the same using extended warranty, he is checking out the same.
is there any simpler way for this fix?
srikanthpotluri is offline   Reply With Quote
Old 29th November 2012, 10:14   #95
Thanked: 19 Times
Suprisingly there has been no response Got my Punto back from service.
They had fixed a new fan using extended warranty now the issue is gone.
Sri
Old 29th November 2012, 17:42   #96
sharath's Avatar
Sri
what was the total cost? (i mean labour charges). thx.
sharath is offline   Reply With Quote
Old 30th November 2012, 12:17   #97
Thanked: 19 Times
since it was clubbed with service of 60,000kms, i am not sure, for the service it costed me another 10k, in which laborwas 1800.
Fiat Linea and Fiat Punto (90 BHP) Owners. Timing chain issue & recall justin.das Technical Stuff 128 5th December 2017 19:56
5 year old Skoda Fabia: Dealer wants to change entire Airbag system! arjab Technical Stuff 13 21st April 2015 19:20
Maruti Suzuki recalls 3796 units of Ciaz to fix faulty clutch Aditya The Indian Car Scene 18 4th December 2014 19:00
Fix for Faulty Fuel Gauge-Maruti Esteem 1997 Kamal Technical Stuff 7 7th July 2011 23:56
All new redesigned Audi TT 2 be shown in 05 _Crazi4Speed_ The International Automotive Scene 3 6th October 2004 10:19
