Old 29th October 2010, 08:15   #1
sfilinto's Avatar
Default Chain at the rear of the Tata Marcopolo low floor buses
On a recent trip to Delhi i noticed that all the Tata Marcopolo low floor buses have a chain dangling at the rear.
Does anybody know what this is for ? Some sort of a gauge ? For the height / loading - similar to small aircraft ??
The Volvo Low floor buses I have seen in Bangalore do not have a similar chain.
sfilinto is offline   Reply With Quote
Old 29th October 2010, 09:02   #2
bblost's Avatar
Thanked: 6,971 Times
If the chain in question is such that it occasionally makes contact with the road. It could be for discharging static electricity.
Which could explain them being present in Delhi and not in Bangalore. Delhi being drier and having a greater possibility of creating static electricity.
PS: This is what I understand by googling, chains at rear of bus.
Old 29th October 2010, 09:50   #3
rajeev k's Avatar
Thanked: 1,750 Times
In yester years I have noticed rear mud flaps made of steel wire meshing for many Ambassador taxis which were also used to touch the road. The explanation for which was similar to above one.
rajeev k is offline   Reply With Quote
Old 29th October 2010, 10:18   #4
Thanked: 181 Times
This used to be seen on petrol tankers as well few years back. Don't see them now, though!
sanjaykk is offline   Reply With Quote
Old 29th October 2010, 10:28   #5
As Bblost pointed out, the old lorries and buses used to have these chains to discharge the static electricity generated to roads as they come in contact with road once a while.
However I thought this was replaced at least a decade back and there is some system to pass these currents back to the battery (Donno details of how its done)
GeorgeV
pvgeorge is offline   Reply With Quote
Old 29th October 2010, 16:04   #6
MileCruncher's Avatar
Thanked: 357 Times
As much as my knowledge goes, the chain has nothing to do with static electricity. If you see carafully, the chain would have also had a metal tagging. As required by the law, each CNG cylinder needs to have its tagging and these are Cylinder tag chains and when it comes loose, you may see it hanging.
MileCruncher is offline   Reply With Quote
Old 29th October 2010, 16:35   #7
Thanked: 63 Times
I believe it is used for current discharge from lightening strikes, like what we have in our apartment tops etc. Imagine the situation wherein the trucks travel alone in vast lands and no conducter for electric charge from sky.
Just my thoughts though
lambuhere1 is offline   Reply With Quote
Old 29th October 2010, 16:42   #8
Thanked: 357 Times
As per basic physics, the electric field inside the vehicle is zero. So if a lightning strikes, the electricity will pass from outside the body and since it is very high voltage, it will go to ground using the path of least resistance that is polarising the air and causing a spark. So a chain is not required.
Top Gear video to partially explain what I'm talking about
Old 29th October 2010, 17:20   #9
Thanked: 420 Times
May be not to discharge the lightining strike but for other static charge like they put for oil tankers.
Static charge is not big enough to polarize the air but can create sparks
amitk26 is offline   Reply With Quote
Old 29th October 2010, 17:40   #10
tsk1979's Avatar
Thanked: 16,418 Times
The buses are CNG and if there is any kind of leak, static electricity can lead to a major fire. Due to this reason, many vehicles have chains dangling down to ground the charge before sufficient buildup occurs.
Old 29th October 2010, 17:51   #11
n.devdath's Avatar
Thanked: 2,144 Times
Tanveer is right, you would see similar chains on explosive trucks as well.
Eicher introduces a "rear engine semi low floor" Bus GTO Commercial Vehicles 16 21st October 2011 22:54
Mahindra Tourister i vs Tata Marcopolo & others - Need a School Bus Finject Commercial Vehicles 22 8th June 2010 21:15
Tata low-floor city buses in Nagpur Ram Commercial Vehicles 20 1st February 2010 14:06
520 Chain (Karizma Chain) Query DeepakMenon Motorbikes 11 10th December 2009 12:29
Tata low floor buses lacking in power, says PMT rahul_intlad Commercial Vehicles 61 18th February 2008 20:38
