Old 29th October 2010, 10:03   #1
speedsatya's Avatar
Thanked: 706 Times
Default Over revving MPFI Zen Engine( revv limiter doesnt cut at 6000 rpm!!)
Team,
The old Zen (mpfi ) has a revv limiter set at 6000 rpm i.e one cant revv beyond 6000 rpm.
But these days ,my car ( 10 years and 1.75 L kms ) which has been maintained at correct service intervals goes upto 7000 rpm!!!.I didnt dare go beyond that .
Wanted to know from the experts as to why do you think is this happening?
Cheers,
Satya
speedsatya is offline   Reply With Quote
Old 29th October 2010, 13:29   #2
wildchild4lyfe's Avatar
the same thing happened with my 01 lancer aswel. my tuner didnt have an answer but man was i enjoying it!!
wildchild4lyfe is offline   Reply With Quote
Old 29th October 2010, 15:23   #3
speedsatya's Avatar
Thanked: 706 Times
Isnt the rev limiter a function of the ECU.I just hope it isnt the ECU
Old 29th October 2010, 17:06   #4
bhp_maniac's Avatar
Thanked: 90 Times
I do believe rev limiter as a feature of the ECU. But if something got messed up with the ECU you should probably get an error code and a check engine right? I suggest, do get it checked from the A.S.S
bhp_maniac is offline   Reply With Quote
Old 30th October 2010, 15:21   #5
Thanked: 89,399 Times
Did you change your battery, or reset the ECU in any way? Some ECUs follow a "learning" curve after being reset. Here is a related thread (NHC engine revv limiter not working?).
All you enthusiastic drivers : Do NOT OVER-REVV GTO Technical Stuff 116 3rd September 2011 20:21
NHC engine revv limiter not working? drsnt Technical Stuff 8 23rd May 2010 21:31
Ractive Tachometer 3.5'' does not cross 3000 RPM on Max Revv bugboy180 Modifications & Accessories 21 23rd January 2009 00:11
Fuel cut-off at max RPM in my Altis! Ym-enjn Technical Stuff 49 28th November 2008 16:48
99'ZEN carb to ZEN mpfi.... Balram Modifications & Accessories 17 10th December 2006 09:04
