Old 31st October 2010, 23:27   #1
Thanked: 27 Times
Default Reluctance in increase in RPM
Hello bhpians,
This is about a problem that I see in my friends car. The car in question is a 2004 esteem. The tachometer works properly (I presume) since the idling without the ac on shows 800-900 rpm and with the ac on shows 1100 rpm. On pressing the accelerator during stationary, the rpm does not go over 3000 rpm. Even whilst driving there is a reluctance in going over 3000-3500 rpm. The car's meter mentions the redlining at 6000 rpm.
On a Getz ive observed whilst stationary the car can be revved to 5000 rpm.
What could be the problem ?
The car has got an oil change done just 1000kms back ?
kavesh55 is offline   Reply With Quote
Old 2nd November 2010, 17:13   #2
Thanked: 89,063 Times
Kavesh,
- How many kms has the car run? Is she throwing out a check engine light? This sounds similar to what I faced once when my car went into "limp home" mode (i.e. safe mode).
- Sounds like a problem with air flow. Check that your air intake / air filter isn't choking. If that's okay, check the fuel filter if its clogged up. Next, check the MAF / O2 sensors and fuel pump (for inadequate pressure)
I sure hope he filled the right oil!
Old 2nd November 2010, 18:06   #3
Thanked: 27 Times
The car has run 36k kms in all. 34-35k when it had gone for a tune up, which included a change of oils and filters.
will check the air filter.
Old 4th November 2010, 03:26   #4
IndrojitSircar's Avatar
Thanked: 113 Times
A choked Catalytic converter could also be the reason for making the RPM reduce. Since the car has got a new set of filters i presume that it shouldn't be a problem of a choked air cleaner or a Fuel filter. The Rev limit on this car is 6700 RPM so it is definitely under performing. Keep us updated on the status of the car.
Old 6th November 2010, 15:22   #5
dhanushs's Avatar
Thanked: 4,054 Times
Check if your induction coil is OK. Inspect/Clean and replace spark plugs, cord wires if necessary.
Still if the problem persists, I would suspect fuel adulteration, and cleaning of fuel filter/tank/lines is recommended.
Old 20th November 2010, 21:20   #6
Thanked: 27 Times
The engine was scanned, all the sensors are working. There may be two issues-
1. The plug wires my not have the necessary resistance
2. The optical sensor in the distributor needs to be checked.
Is Fuel efficiency strictly a function of RPM or is it speed+gear+RPM? Astleviz Technical Stuff 54 25th November 2011 09:22
i10 Sportz - Rattle behind steering column & RPM increase subhashnm Technical Stuff 8 14th June 2010 16:25
ABS Motors, Gurgaon: Reluctance to service my Punto khan75 Indian Car Dealerships 12 3rd April 2010 10:52
rpm below idle rpm tortoise Technical Stuff 12 2nd April 2007 00:51
Does a TC increase the CC of an engine? Shan2nu Technical Stuff 8 20th October 2004 03:40
