Old 2nd November 2010, 19:49   #1
Thanked: 3,962 Times
Default What's a Continuous Variable Cam phaser and "Intelligent Port resizer" on 1.4 FIRE?
I need some information on the two terminologies.
The Fiat 1.4 FIRE petrol (normal 90 PS), also called the 1.4 SAFIRE by Tata is heavily promoted by tata as having these two techical terminologies:
  • CVCP (Continuous Variable Cam phaser), also present in the 1.2 FIRE
  • IPR (Intelligent port resizer)
While I do get that CVCP is something to do with similar to VVT tech. But how is it different from Variable Valve timing tech?
And secondly, what really is intelligent port resizer?
Expert advices needed.
sidindica is offline   Reply With Quote
Old 2nd November 2010, 19:55   #2
pranavt's Avatar
Thanked: 274 Times
Variable valve timing (probably similar to Toyota's implementation in the way that both technologies have continuous variation as opposed to something like Honda's VTEC which is either on or off) and Variable length/diameter intake/exhaust
Old 2nd November 2010, 20:25   #4
Thanked: 31 Times
@argee: You mean CVCP (Continuous Variable Cam phaser) is same as Variable Valve Timing technology?
EARTHed is offline   Reply With Quote
Old 2nd November 2010, 20:28   #5
rjstyles69's Avatar
Thanked: 795 Times
sid quoting from an older post of yours made here.
The drive refinement of the Indigo MANZA stems from the internationally-acclaimed 90 hp Quadrajet Diesel and Safire Petrol engines, sourced from Fiat. The petrol engines are configured using a Continuous Variable Cam Phaser, which smartly adjusts valve timings and intervals for power delivery. In addition, the electronically controlled Intelligent Port Resizer (IPR) function in the Safire engine delivers a perfect balance of power and economy. The Quadrajet diesel engine features a Variable Geometry Turbocharger for smoother running and an aluminum bedplate along with superior insulation that reduces NVH levels while delivering a superior power to weight ratio. The Drive by Wire technology virtually eliminates all “throttle lag” leading to a faster, smoother response.
Old 2nd November 2010, 21:31   #6
Mpower's Avatar
Thanked: 1,687 Times
CVCP is nothing but a toyota style VVT.
Old 2nd November 2010, 21:38   #7
Thanked: 31 Times
The Vista website clearly mentions -->
Engine Type: Twin Cam Variable Valve Timing Technology.
What's a Continuous Variable Cam phaser and "Intelligent Port resizer" on 1.4 FIRE?-untitled.jpg
Old 3rd November 2010, 11:10   #8
I still doubt that CVCP is same as VVT. Than how can Hyundai claim "first in class VTVT tech" for its i10 when the vista 1.2 safire also competes with it in the same price tag? I think that some functioning is different.
But what rjstyles quoted my post is also written in the brochure.
What I want to know is what exactly the Intelligent Port resizer thingy? The technical guys at Tata are clueless about it.
Old 4th November 2010, 17:42   #9
Mpower's Avatar
Hmm...that's sounds like Hyundai's problem.
BTW, wasn't the Jazz first in 1.2 L segment to offer variable valve timing?
WW2 Continuous Track Vehicle - Please identify? eagle_f1 4x4 Vehicles 12 13th June 2010 13:59
intelligent ECUs. how intelligent? blacmagic Technical Stuff 13 27th November 2009 19:19
Enfield Bullet:Cam gear backlash and solutions including adjustable cam spindles deepclutch Motorbikes 73 17th December 2008 00:47
