Old 13th December 2005, 15:53   #1
Akkiben's Avatar
Default Relay for headlight
Hi Guys, I have recently put 90/100 Philips H4 halogen bulbs for my Santro. I wanted to be sure whether fitting of Relays is a MUST. If yes, could someone tell the required rating for the RELAY and preferably the procedure for fittment.
Akkiben is offline   Reply With Quote
Old 13th December 2005, 16:23   #2
tsk1979's Avatar
Thanked: 16,421 Times
Relay is a must. Otherwise you will blow your fuses frequently and may also damage your wiring. It costs 300rs total. If you get it fitted from authorized workshop it will cost around 600rs.
Old 13th December 2005, 16:33   #3
Badcheetah's Avatar
Thumbs up
Originally Posted by tsk1979
Relay is a must.
I second that ...
all the additional loadmight just play havoc at the worng time and we dont want that right .
They cost around that much only.
Badcheetah is offline   Reply With Quote
Old 13th December 2005, 17:33   #4
Akkiben's Avatar
Alrighty then. That's what I wanted to hear. Shortly I will be making 600kms+ trip along the west coast all the way upto Karwar, hence I required better lights. Those 90/100W bulbs sure put out a lot of heat though, could fry an egg on it I guess.
Could you explain the fittment procedure for relays?
Old 13th December 2005, 19:25   #5
speedsatya's Avatar
Thanked: 712 Times
go to any hyundai workshop and get a relay fitted ...u get Lucas and Bosch relays for under 500rs
speedsatya is offline   Reply With Quote
Old 13th December 2005, 20:48   #6
msprabhakar's Avatar
Thanked: 73 Times
Hey Akkiben, Carthick99 seems to be an expert in lighting. See his posts, especially http://www.team-bhp.com/forum/126577-post12.html.
msprabhakar is offline   Reply With Quote
Old 14th December 2005, 00:14   #7
nitrous's Avatar
Thanked: 285 Times
You definitely need a relay. And if ur car is still in its warranty period, get the relay fitted in a hyundai service centre and ask them to give in writing that ur warranty isnt void after fitting the relay and the 100/90 headlamps.
Old 14th December 2005, 09:46   #8
viper's Avatar
Thanked: 9 Times
Hey Guys,
I doubt if the HSC will carry out the changes. At least in Mumbai they dont. But if you what Carthick99 said in the below link point 1 there should be no harm. I have been doing the same in all my car sfrom the past 15 years. No problems other than once when the relay got spoilt. All I had to do was change it. It cost Rs100. A proper original relay + wiring job should cost you at least Rs.900/-. Thats what any good electrician in Mumbai will charge. I suggest spend that extra 3-400 and get a good job done rather then do a road side cheapy job done.
Viper
viper is offline   Reply With Quote
Why relay for high watt lamps DRC Technical Stuff 11 9th September 2010 22:34
Headlight relay for new Swift abhaybakshi Technical Stuff 13 18th January 2010 09:32
Is my headlight relay gone Kaput? WAGON_R Technical Stuff 9 3rd March 2009 11:36
Relay : Bosch or PMP venkatrx Modifications & Accessories 10 19th January 2009 16:46
How important this small relay is.......views invited ECM Technical Stuff 5 10th May 2006 22:46
