Old 9th November 2010, 12:12   #1
nishad.hameed's Avatar
Thanked: 17 Times
Default Zen AT - query on autobox
Friends,
just bought a used card, 2002 model Zen AX/AT for my wife. The query is on the autobox.
the available transmission are P, R, N, D, D2, and L.
someone please help on finding the difference between D, D2 and L? for me, on driving it feels like shifting down from D to D2 and L.
nishad
nishad.hameed is offline   Reply With Quote
Old 9th November 2010, 12:40   #2
dhanushs's Avatar
Thanked: 4,507 Times
I'm not so familiar with these Auto box's but, AFAIK,
D - Regualr Drive mode, in which box' uses all gears.
D2 - A shorter version of D, and only gears 1 & 2 are used.
L - Should be Low gear, where only 1st is used.
- Experts please comment.
Old 9th November 2010, 12:47   #3
dhanushs is correct.
Most cases you will use only 'D'.
D2 / L comes into play only during 'down slopes' where you need to restrict the car to 1st or 2nd gears only.
jigbarai is offline   Reply With Quote
Old 9th November 2010, 13:43   #4
Dippy's Avatar
Thanked: 192 Times
Hi nishad
Its pretty simple that way. Use only D for your every day driving. Your Zen AT comes with a 3 speed auto box. In D mode the tranny shifts all three gears . In D2 it will shift only gears one and 2 and stay that way. In L mode only one gear will be available. use D2 and L to negiotiate steep inclines when driving. These modes give you extra torque.
In normal driving D, if you want to = down shift in order to shoot off or in case of overtaking, just push down the pedal hard and the gear box will perform a downshift.
Dippy is offline   Reply With Quote
Old 9th November 2010, 17:46   #5
Thanked: 17 Times
clear! it helped!! Thank you everyone.
Innova Purchase Query + Query on Price Increase by Toyota SanMan SUVs, MUVs & 4x4s 7 30th April 2008 13:13
Zen Di Tyre Query furioussphinx Tyre & Alloy wheel Section 21 22nd March 2008 19:05
Audio Query for Zen vidvai In-Car Entertainment 14 14th August 2007 10:47
