| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Mar 2005 Location: Navi Mumbai
| I have a query. As the Airbag is fitted in factory what happens after accident and Airbag is deployed. 1. Does the dealer is able to rplace it or the vehicle has to be sent to factory. 2. Does the replacement cost is covered in insurance fully or it is deprecaited same as plastic parts ( 50 % in first year itself) 3. IF it can be done at dealer level then why not offer it as standard fitmment /accessory like car security system.
__________________ It is never too late.- get your safety options right |
| | #2 (permalink) |
| BHPian Join Date: Feb 2005 Location: mumbai
| the dealer has to replace the entire airbage section of the dashboard once it has been deployed .or the steering wheel . it cannot just stuff it back in . insuarance does not cover airbag replacement . and the airbag system is quite complex accelerometer next o the bumper and in the doors ! |
| | #3 (permalink) |
| Senior - BHPian Join Date: Dec 2004 Location: Windsor
| dude .. once an airbag is deployed the whole dashboard is completely ripped (incase of the passenger airbag) ..the whole dashboard console the steering wheel bit everything have to be replaced .. remember the Totalled vectra thread ?? the passenger airbag deployed even when there was noone sitting next to the driver causing unessecary damage..i think with the passenger airbag option they should have a passenger seat occupied sensor *Standard* ..
__________________ Every weapon needs a master |
| | #6 (permalink) |
| BHPian Join Date: Dec 2005 Location: Mumbai
| Do we require ABS in Indian condition. ABS is mainly used for snowy or ver slippery conditions and also for very high speed driving. As these conditions are not common in India, do we still need ABS ? Kash |
| | #7 (permalink) |
| BHPian | I would say ABS is a MUST on indian roads, city and highway. You never know when an auto rickshaw or a bicycle will come darting out of a cross steet! On the highways, its hard to predict when that cow will decide to get up from the middle of the road! A lot of uncertainty and when something jumps in front of you, natural reflex is to hit the brake pedal with everything that you got! ABS will definately come in handy and IMO, should be a safety feature required on all cars. I dont mean anything negative but I am sure most people here will agree with me when I say that most drivers on Indian roads have little respect for the traffic rules, and in most cases, never recieved proper drivers education. |
| | #8 (permalink) |
| Senior - BHPian | Importance of ABS has been discussed at length in the following threads. http://www.team-bhp.com/forum/buckle...?highlight=ABS http://www.team-bhp.com/forum/indian...?highlight=ABS (Your new car must be equipped with these) Drifter
__________________ Slow Everything Down And Feel Like God - Tata Safari |
| | #9 (permalink) |
| Good observations idnani. I guess the cost of ABS will offset the safety aspect. Infact i was in two minds whether to go for ABS or not for the Ford fiesta i have booked. Whether Rs 25K extra is required or the disc brake provided with the car is enough. |
| | #10 (permalink) | |
| BHPian | Quote:
If you need to stop ASAP, then by reflex one tends to hit the brakes hard so ABS will kick in then. In fact, with powerful brakes (large discs) and skinny tires, wheels will lock easier. | |
| | #12 (permalink) |
| BHPian | Infact most of Indian cars have smaller discs than required which allows for the inertia to take those extra feet before stopping under tight peddaling but not slamming. Also, the inertia load avoids disc locking(thanks to disc slipping due to insufficient disc size), now this is more like a natural ABS!!! But the principle of ABS is different, an ideal ABS is a big, powerful disc with enough stopping power but with anti caliper lock mechanism. Speaking about its relevance in India, I think it should be made mandatory atleast to all the 1L and upward automobiles.
__________________ Spine splitter... |
| | #13 (permalink) |
| BHPian Join Date: Oct 2005 Location: Bangalore
| As far as i know, ABS does not reduce the stopping distance of cars. It just ensures that we have steering control. Correct me if im wrong. Infact i've read that on particular road conditons(gravel probably), the stopping distance is increased compared to that of a car without ABS. |
| | #14 (permalink) | |
| BHPian Join Date: Feb 2005 Location: Loveland, OH (cincinnati area), jabalpur, chennai
| Quote:
if you are a good driver driving on a good surface, you can stop at a shorter distance without ABS than with ABS. it's like advantage of manual gear over auto. but if you skid (for whetever reason), the braking distance will be shorter for the ABS equipped vehicle. choose your pick ![]() | |
| | #15 (permalink) |
| http://www.nhtsa.dot.gov/cars/proble...absbrakes.html http://www.abs-education.org/faqs/faqindex.htm Quoted from the same webpage There are some conditions where stopping distance may be shorter without ABS. For example, in cases where the road is covered with loose gravel or freshly fallen snow, the locked wheels of a non-ABS car build up a wedge of gravel or snow, which can contribute to a shortening of the braking distance. |
| Thread Tools | |
Similar Threads | ||||
| Life of a car engine under indian conditions | adityapd | Technical Stuff | 146 | 8th August 2009 22:06 |
| Logan 1.5 with ABS/AIRBAG | muke31 | The Indian Car Scene | 34 | 7th July 2008 12:46 |
| All that I D(e)zired - UVA LT ABS+Airbag on the way | Firebird | Test-Drives & Initial Ownership Reports | 40 | 6th June 2008 11:48 |
| Help selecting Tyre for NHC vtec (ABS+AIRBAG) | vvvinod | Tyre & Alloy wheel Section | 4 | 7th May 2008 11:22 |
| Ford India introduces new Fiesta line-up with ABS, DRIVER AIRBAG, 1.6 ZXI and more | sidindica | The Indian Car Scene | 37 | 14th February 2008 17:30 |
