Old 14th December 2005, 10:08   #1
vivekiny2k's Avatar
Thanked: 184 Times
Default the bearing used in handle bar of bikes
can anyone throw light on the type of bearing used in the handle bar of a bike, that allows the left right steering.
i have been feeling jerks when i pur front brakes, and i feel the bearing has gone loose. i also doubt if it was checked in regular service, but before approaching the mech,i wanted to know if it's a frequently serviced and replaced part.
Thanks.
vivekiny2k is offline   Reply With Quote
Old 14th December 2005, 10:23   #2
dogdiga's Avatar
Are you the Wipro Guy from swift_india yahoo group
dogdiga is offline   Reply With Quote
Old 14th December 2005, 10:29   #3
vivekiny2k's Avatar
Thanked: 184 Times
no buddy. you are referring to somebody else.
Old 14th December 2005, 10:44   #4
Rtech's Avatar
Thanked: 221 Times
It should be a regular caged ball bearing.
To check, put the bike on the main stand and raise the front wheel in the air a bit. Then, with the front tyre between your legs, try and move the forks vertically. If you feel some play, try tightening the big nut in the center of the top yoke. If there is still play in the stem, you would have to change your head bearings.
Old 14th December 2005, 10:48   #5
dogdiga's Avatar
http://travel.howstuffworks.com/bicycle.htm
http://auto.howstuffworks.com/motorcycle.htm
Check these out. They might help.
Fabricating handle bar risers for a better riding position ani_meher Motorbikes 29 8th December 2017 21:25
Wobbling Handle Bar sagarpadaki Motorbikes 29 17th November 2014 19:27
Handle bar change for Pulsar 150 cruiser_1982 Motorbikes 4 6th December 2009 21:20
