Thread Tools
Old 14th December 2005, 13:16   #1 (permalink)
pratheesh's Avatar
Smile Are High Octanes really high OCTANE
Please tell me whether high octane petrols are really made of those highly branched octane................or are they called because of their high octane numbers...
i asked this question because, ethyl alcohol is said to ve an ocatne rating of 127, and when mixed with petrol it should exhibit high octane rating....
though ethyl alcohol, according to latest trends, is a better fuel than petrol...when used in a petrol engine will deteriorate the rubber sealings and pipes...it may also produce high temperatures...
also the advertisements claim their fuels are capable of CLEANING the interior of engine from dirt n soot....which is possible when ethyl alcohol is used...
also provide me with the ingredients of premium petrols...
please clear my doubts....
__________________
What it is unique for Indian Cricket Team?
Ans:- The batsmen are good at bowling and the bowlers are good at batting!!!
pratheesh is offline   Reply With Quote
Old 14th December 2005, 14:21   #2 (permalink)
quicksilver's Avatar
yes high Octane petrols really do have a high Octane content as advertised. This can easily be experienced in the older cars where the engine knocking will be reduced to a good extent. However, on modern cars there is an advanced ECU along with Knock sensors etc which adjust the fuel/air musture automatically and hence the higher octane does not really make much of a difference in modern cars, except an improvement in FE.
Speed/XTraPremium etc all contain regular fuel + additives. these additives are what is said to clean up the fuel systems and it is not comprised on Ethanol. Though most of the dealers advise not to use Premium fuels, my advice would be to spend that extra buck and go for Premium. I have been using XTraPremium only on my 2003 Honda City and have had no issues whatsoever so far. The car is only getting better as days pass
__________________
The world looks different after 5000 RPM in my rear view mirror!
quicksilver is offline   Reply With Quote
Old 16th December 2005, 11:07   #3 (permalink)
pratheesh's Avatar
but think, ethyl alcohol can do the same detergent effects (cleaning), and of course is a cleaner, cheaper fuel than petrol.......
but the only problem is that more heat is produced when burning ethanol....
why is it that ethyl alcohol is not accepted as a motor fuel in India...
Petroleum lobby????
__________________
Old 16th December 2005, 11:54   #4 (permalink)
tsk1979's Avatar
Shortage of so much ethyl alcohol. Till recently it did not make economic sense. Now with govt intervention 5-10% mix will be there soon. I would term it down to petrolium lobby, Govt laziness, lack of initiative from manufacturers, and low priced diesel.
__________________
Reclaiming.....!
Old 19th September 2006, 23:50   #5 (permalink)
Yes..premium fuels like Speed and XTra Premium are definitely worth the extra buck..they make a great difference in driving.FE also improves,though marginally.
Ethanol is not good for the engine if its concentration in petrol is over 5%.There are proposals to blend motor spirit with ethanol .That is one more avenue to lower the cost of fuel ex Refinery and raise profit margins.Gradually the concentration of ethanol in motor spirit would rise and and unsuspecting customers' cars engines would face the music !!!!
Old 20th September 2006, 00:53   #6 (permalink)
Steeroid's Avatar
ADNOC (Abu Dhabi National Oil Co) has promised to release a new variant of gasoline in the market here which will be cheaper than the existing fuels (93, 95 and 98 octane). Perhaps this is regular 89 octane which is not available here, or perhaps they're planning an alcohol additive......will keep you guys updated.
but I bought STP Fuel System Cleaner for my car today and it had a large sticker which said "Made with Jet Fuel!". If I'm not mistaken, Jet Fuel is KEROSENE and the damn concoction smelt very much like kerosene....is that all it takes to clean up injectors?
__________________
Steer
Petrols Suck. Diesels Torque. Q.E.D
Steeroid is offline   Reply With Quote
Old 20th September 2006, 11:02   #7 (permalink)
I thought naphtha and kerosene were adulterants, not cleaners
sandeep108 is offline   Reply With Quote
Old 20th September 2006, 11:30   #8 (permalink)
tsk1979's Avatar
Jet kerosine is not something you get from local hatti. Its highly purified Kerosene and is really really expensive. How much you pay for your air ticket depends quite a bit on the price of Jet kerosine in the international market.
__________________
Reclaiming.....!
Old 20th September 2006, 11:59   #9 (permalink)
Of course I know, tsk - just a light moment...
Old 20th September 2006, 22:48   #10 (permalink)
gd1418's Avatar
Infractions: 0/1 (4)
Default Premium fuel
This is very strange. I have a 2004 Accord 3.0 and initially used Speed from BP. The vehicle started giving probs. While accelarating there were hiccups. Switched pumps and started using Power from HP. Initially ok and then the same problem cropped up. So, finally consulted the workshop - Ring Road Honda. Was very clearly told to use normal petrol only without additives. Listened to their advice and no problems whatsoever there after. I've no explanation to this. The same thing was corroborated by a fellow Accord 2.4v user. Any comments???
gd1418 is online now   Reply With Quote
Thread Tools
How does high octane fuel improve performance? DCEite Technical Stuff 90 19th June 2008 11:53
premium diesels do they work like high octane petrol garvit2002 Technical Stuff 2 20th February 2006 09:54
High Octane and Maruti pratheesh Technical Stuff 24 10th February 2006 21:30
High Octane Fuel Domnic A Collection of the best threads 88 27th October 2005 15:34
High Octane for NHC? srasania Technical Stuff 6 28th May 2005 20:24
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
