Old 14th December 2005, 15:37   #1
amitoj's Avatar
Thanked: 1,691 Times
Default Variable compression ratio engine!
Hi
Long time since i started a thread.
A friend of mine sent me a link to an article that explains an engine developed by Saab that can vary its compression ratio from 8:1 to 14:1 depending on the load on the engine! As per the article, Saab says that it reduces fuel use by 30 percent and the engine is as powerful as an engine twice its size. However, this is still under R&D phase and still long way away from production.
Here is Ze Link
amitoj is offline   Reply With Quote
Old 14th December 2005, 19:11   #2
Shan2nu's Avatar
Thanked: 89 Times
From 8 to 14 on a petrol engine???? What kind of fuel will you have to fill to run a 14:1 compression engine?
Shan2nu
Old 14th December 2005, 20:34   #3
Mpower's Avatar
Thanked: 1,687 Times
Same fuel. It will run 14 under part throttle and 8 under WOT with max boost.
Old 14th December 2005, 21:39   #4
Shan2nu's Avatar
Thanked: 89 Times
Same fuel.
I know that but, what octane fuel?
Shan2nu
Old 15th December 2005, 01:48   #5
Mpower's Avatar
87-89 octane should be OK.
Old 15th December 2005, 23:32   #6
Default Variable Stroke Engines
According to my information variable stroke engines are used to measure the knock tendency i.e. cetane and octane numbers of fuels.
If you want to have a look, generate contacts and visit Themodynamics laboratories of IIT powai or Naval College of Engineering, INS Shivaji, Lonavala
samcore is offline   Reply With Quote
Old 20th December 2005, 14:31   #7
I dont get it. Do you mean like changing the compresion on the fly without opening the hood? If not it's not so impresive( an A series toyota can do that 9-15 last check).
newbie is offline   Reply With Quote
Old 20th December 2005, 14:45   #8
sbasak's Avatar
see here
http://en.wikipedia.org/wiki/Compression_ratio
sbasak is offline   Reply With Quote
Old 20th December 2005, 21:01   #9
ananthkamath's Avatar
Thanked: 63 Times
Right and wrong.
The engine your talking about is the CFR (Co-Operative Fuels Research) engine which can vary CR from 4:1 to 18:1 through a movable cylinder head. Obviously it is not practical in an automotive installation due to its single cylinder and purpose.
The engine designed by Saab also uses a movable cylinder head but it works in conjunction with a Rootes supercharger to maximise volumetric efficiency.
ananthkamath is offline   Reply With Quote
Nissan's new gamechanger: VC-T engine with 'variable compression ratios' RavenAvi The International Automotive Scene 17 30th September 2016 11:24
Changing Compression Ratio & Gear Ratio adheesh Technical Stuff 7 3rd October 2007 09:54
Compression Ratio and NOS Ford Rocam Modifications & Accessories 9 28th June 2005 03:13
Vtec's compression ratio!!! Shan2nu Technical Stuff 8 7th May 2005 23:07
