Old 11th April 2014, 15:40   #16
Thanked: 95 Times
Default Re: Wagon R suspension overhaul - Need advice
i have my doubts that this has anything to do with lower arms/suspension. Have the brake calipers checked thoroughly. Also I dont get what lower arms having play means.
zoombiee is offline   Reply With Quote
Old 11th April 2014, 16:14   #17
arnabchak's Avatar
Thanked: 1,101 Times
@ Zoombie
Exactly my thoughts.
Even I could not understand the term Lower arm has play as I know that to one one consolidated unit.
My break pads are due for change. Can the calipers be checked during this.
What should be the cost of brake caliper servicing be?
arnabchak is offline   Reply With Quote
Old 11th April 2014, 18:06   #18
narendra.vw's Avatar
Thanked: 402 Times
Mechanics term, Lower arm play means Rubber bush has become weak & ball joint on the lower arm lost it’s life. This can be found out only after removing the lower arm.
Most important suspension part with respect to handling.
narendra.vw is offline   (1) Thanks Reply With Quote
Old 11th April 2014, 22:45   #19
rajeev k's Avatar
Thanked: 1,750 Times
Originally Posted by arnabchak View Post
I am getting a continuous screeching noise from my front left suspension area.
the MASS attendant told me that this is due to a hardened rubber and also the lower arms may have some play.
The total estimate including labour would be approx. 8K.
Screeching noise can emanate from the lower arms. Change them and the strut rubber bushes. Inspect the steering tie rod end ball joints. Replace them also if it had developed play. Expenses for spares and labor would be below Rs 3.5K only.
rajeev k is offline   (1) Thanks Reply With Quote
Old 12th April 2014, 11:18   #20
arnabchak's Avatar
Many Thanks Rajeev.
Your diagnosis seems spot on.
The MASS had also diagnosed a similar issue but their quote was almost thrice the mentioned quotes:
1) Tie Rod/Lower Arms + Labour- Rs. 5.5 K
2) Steering Rod-Rs. 5K
Taxes++.
Old 12th April 2014, 11:56   #21
Thanked: 14,600 Times
Taxes++.
I suggest you to go to the MGP dealer in your city, pick up the required parts and get them fit on your car at a KNOWN FNG, if any. Taxes and labour saved as the FNG rates won't be so exorbitant.
Anurag.
Old 24th November 2014, 12:38   #22
nishantdlv's Avatar
Thanked: 197 Times
Originally Posted by smarth.katyal View Post
Getting back to the point, ive been experiencing cabin noise from almost 60k kms onwards. But i could get it corrected at every service by replacing and greasing(silicon grease) the caliper pins on both the front brakes. No noise after that. So i would advice you to check your calliper assembly and pins for proper lubrication and wear and tear. But now,the pins seem to be in good condition and still have lots of noises, and since its nearing the 100k mark,what components of the suspension give way? and how much will they cost? My trusted MASS says my steering assembly is also going kaput,this he could say by turning the steering with a jerk when the car was standing and it made a tuk-tuk noise. He says part of the noise even when driving can be attributed to the steering assembly.
Hey! Even I'm experiencing a similar problem since a few months now. Any updates on the same? Did you go for a suspension overhaul, and if yes, how much did it cost?
nishantdlv is offline   Reply With Quote
Old 15th February 2015, 11:50   #23
Thanked: 32 Times
Hi sorry for the extremely late reply. I gave my car for complete suspension overhaul and steering assembly replacement after gathering some knowledge on the topic. I was there the entire time when the components were being replaced. The following was replaced:- Rubber bushings(4 nos), steering assemble, tie rods. I might be forgetting something. But this costed around 12k including labour and normal service. The noise had completely gone, steering felt smooth. There are numerous videos on youtube that help diagnosing what parts of the suspension needs to be changed. So you can individually run checks for each part yourself and then see if they require replacement.
smarth.katyal is offline   Reply With Quote
Old 15th February 2015, 15:13   #24
nishantdlv's Avatar
Thanked: 197 Times
Nevermind samarth
Even I got the same things done and costed somewhat the same. Yes, the problem is fixed. Thanks for the reply mate.
Old 2nd August 2015, 11:24   #25
Thanked: 40 Times
Hey,
Have a 2005 WagonR Lxi which has completed 46k kms. Recently changed the clutch plates, did a complete service (rs.2500/-) as per Popular Maruti and then as per them there was some leakage in the silencer and they told that is also fixed. The entire cost came to around 11k
They also intimated me that the suspensions needs a replacement if not now, in the recent future along with the steering bushes.
Can somebody tell me about the pricings of suspensions and the,steering bushes for wagonr???
Bibin is offline   Reply With Quote
Old 2nd August 2015, 13:14   #26
Hey Bibin, while surfing around for parts for the WagonR, I came across this link:
Do look at it and see if it of some help. If not for the parts, pricing will be near about for OEM stuff.
http://www.motrpart.in/model/9/maruti-suzuki/wagonr
a4anurag is offline   (1) Thanks Reply With Quote
Old 3rd August 2015, 00:06   #27
Thanked: 40 Times
I have gone thru it and I can see a brand named Monroe?? Have never heard of it.. Can someone throw some light on this brand? Is it dependable?
Suspension Overhaul narayan Technical Stuff 105 17th January 2018 10:55
Maruti 800 Suspension Overhaul Cost jramprakash Technical Stuff 37 17th February 2017 21:17
Suspension overhaul for Zen skidrock Technical Stuff 18 16th December 2015 11:55
Advice on my old Maruti 800 after suspension and brake overhaul amitk26 Technical Stuff 4 9th January 2009 00:09
