Old 6th June 2011, 19:19   #16
dhanushs's Avatar
Thanked: 4,504 Times
Default Re: Age induced issues with ikon, need help.
Well, short trips do take a toll on FE, engine life and even battery. If the majority usage is in the form of short trips, I would suggest you change to synthetic oil. It provides better lubrication whist warm up.
Also, somehow I have felt my IKON drinks a lot of petrol on firing up.
Old 7th June 2011, 12:46   #17
benbsb29's Avatar
Thanked: 4,277 Times
Originally Posted by Fordmanchau View Post
I also warm up the engine for around 1 minutes daily, which might have also helped in lowering FE.
You dont need to warm up the engine for that long. Start the car, and after bout 10-20 secs, move off, but do not stress the engine early on. That should suffice.
Regarding mileage, i get a constant 12-14 kmpl for about 20 kms one way, per day. This is with about 70% A/C usage.
EDIT : My car also needs to get the suspension checked. Its been creaking from the front ove rbad roads, and speedbreakers. Looks like others too have had this attended to at about the same odo mileage.
Old 7th June 2011, 14:18   #18
xbox360's Avatar
Thanked: 76 Times
Lucky for you as you have the Flair and not the 1.6.
Looks like most folks who have the 1.6 are getting under 10 a litre :(. Guess I have no other option but to get used to this (it only gets harder with petrol at 70+ a litre.).
xbox360 is offline   Reply With Quote
Old 7th June 2011, 14:29   #19
Fordmanchau's Avatar
Thanked: 302 Times
Get it Ben, time to save some fuel. Will cut down the warm up time to 20-30 seconds. I generally let the engine warm up till a little after the revvs settle at around 900rpm. I can make the distinct noise of revvs getting lower, when the engine warms up while I clean the car.
Ah-ha, you have a 1.6 and still you complain about the mileage mate.
Not done. On the contrary you are getting a good FE.
FYI, I too have a Flair 1.3
Infact, Benbsb29, Dhanushs, sammyboy and me, all have a 1.3 rocam.
Why play Xbox when you have 1.6? hehe!!
Fordmanchau is offline   Reply With Quote
Old 7th June 2011, 14:54   #20
xbox360's Avatar
Thanked: 76 Times
Looking back, i can only blame my decision to buy this guzzzzler then on either my shortsightedness or probably on my over the top expectations of how my affordability will go up with time
Old 7th June 2011, 21:14   #21
Thanked: 78 Times
..my over the top expectations of how my affordability will go up with time
Don't we suffer from this all the time? :-)
fordday is online now   Reply With Quote
Motion Induced Blindness throttleking Street Experiences 73 26th April 2012 10:30
Ford Ikon - Issues - Need Help reachmash Technical Stuff 19 3rd June 2009 11:57
URGENT help needed: Ford Ikon issues gaurav_diavolo Technical Stuff 8 10th May 2009 17:52
Ikon 1.6 : Apollo Acceleres : Early Tyre Wear Issues-Need Advice abhik Technical Stuff 15 15th May 2008 11:19
honda suspension issues-need help nitroxx Shifting gears 1 28th January 2005 20:54
