| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Team-BHP Moderator ![]() Join Date: Oct 2005 Location: Hyderabad
| Guys I have a 5 month old Indica DLS. It has now closked about 4000kms (effectively ran for 3 months) and is coming up for its first service. I have noticed that every morning when I start the car nowadays in the morning it starts with a squealing sound... This squealing and screeching sound persists. During this time I do not move the car. After about 1min 15 secs or so all of a sudden this squealing noise more or less stops abruptly and the RPM goes up subtly (to around 975 from the earlier 950 or so). It looks like it has something to do with the onset of the winter season. I do not think I noticed this initially. That is till till a month or two back, when the mornings became somewhat cold. Nonetheless this sound worries me a lot. It almost sounds like a two rusted pieces of gears are creaking and groaning. Could anyone tell me what this sound could be? Why it comes in the early morning cold start and why it vanishes after a minute or so? I am anyhow planning to mention this to the dealer when I take it for service. |
| | #4 (permalink) | |
| Quote:
Its just the first minute problem in the mornings. | |
| | #5 (permalink) |
| BHPian | Belt noise.It's a common complaint found in Indicas and the old TUD5 engine which was used in the Esteem,Zen and the old Accent DLS.Nothing a wayside mechanic can't cure.Be warned,it's going to crop up now and then,especially during cold starts.
__________________ Most local cops know me well...from speed camera 'profile' snaps! |
| | #6 (permalink) |
| Senior - BHPian | strange coincidence!!!!!even my zen has started making these screaming and squealing noises when i start ii in the mornings.has just started in winters,never faced this problem before.also had given the car for servicing a week back and after a few days it started making these noises.if it is the alternator belt,what is the connection between the cold weather and the sound.please help me out too.
__________________ Kenwood KDC-MP6539,Image Dynamics Q450.4,Image Dynamics CTX65cs,IDQ15 |
| | #7 (permalink) | |
| Quote:
hellspawn, does it stop automatically for you as well? I typically let the car idle for a minute and a half before I engage the gear. As I said, after a minute or so the sound stops abruptly, the engine gets a little busy as I can make out from the sound and the tacho. This is when I engage the gear. I will anyhow check it out during servicing, but that is still some time away (at least 15 days). | |
| | #8 (permalink) |
| BHPian | Well, If you guys are sure its the belt sound, then I can give you the reason. During winter, the pulleys tend to be cold and there is mist formation on the metallic surface. If the belt is a bit loose, it tends to slip and generate the sound. Now another major reason why this is happening could be due to the cold start itself. Car batteries charges itself if they are warm, in cold condition the battery isnt working in its optimum state. Also Cold start require more cranking and hence huge discharge from the battery (specially in diesel cars). Now Due to this, the alternator gets fully loaded when the car is started (To recharge the drained battery). Now the wetness and the reduction in belt tightness makes it easier for the pulley to slip than turn with the belt. Hence the sound But after a min or so starting, the heat generated by the friction removes the slip and the battery is recharged becoz the alternator does its job and the load on the alternator reduces. Tightening the belt to the optimum condition and replace if necessary. Also check battery condition. Hope this gives a clear idea. Well this happens in my santro too. Especially if i use my music system for prolonged time with the car turned off during winter season. Sometimes the belt is so loose the everytime i start the car early morning during winter it makes this stupid sound. I make sure that they tighten the belt when i go for service.
__________________ Funniest thing about this particular signature is that by the time you realise it doesnt say anythin its 2 late to stop reading it |
| | #9 (permalink) | |
| Quote:
Achchhaa! Your Santro too makes this sound, does it? Hmmm... possibly other makes also do. I initially thought that this is an Indica special So now I know, zen, santro, accent. Hmmm... then this is general physics rather than any specific part problem. Tightening the belt should be a straight forward job. | |
| | #10 (permalink) |
| BHPian Join Date: Mar 2005 Location: goa
| If your belt is over 25,000 km run, replace it with a new one, and tighten properly. In other cases make sure they follow proper procedure to tighten belt to manufacturer's specs. This problem occurs in a new belt only if it has not been tightened to proper specs by a lazy garage.
__________________ Hyundai Getz 05 Baleno Vxi 05 |
| | #11 (permalink) | |
| Senior - BHPian | Quote:
the next day i figured that whatever it was,was due to the cold weather so as soon as i started the engine,i revved the engine a couple of times and voila! the sound was gone.but now il go the garage and get it checked.thanks guys......
__________________ Kenwood KDC-MP6539,Image Dynamics Q450.4,Image Dynamics CTX65cs,IDQ15 | |
| | #13 (permalink) | |
| Quote:
| | #14 (permalink) | |
| Quote:
| | #15 (permalink) | |
| BHPian | Quote:
BTW, Zappo, you have to be prepared for these occassional squeaks with the Indica ... if you want a complete list of "what sounds mean what is wrong" for the Indica, PM me... I have a V2 that has done 40K so far and have seen all that.
__________________ iVTEC and MIVEC in the garage.... Still, the trusty old 1.5 is my daily drive | |
| Thread Tools | |
Similar Threads | ||||
| What's that sound ?? | four_tire | Technical Stuff | 77 | 1st September 2008 20:03 |
| Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? | DieselFan | Technical Stuff | 4 | 25th January 2008 17:31 |
| Need help for sound dampening | mod_to_odd | Ask the Gurus | 1 | 11th July 2007 06:43 |
| Body Sound | andr3whiho | Technical Stuff | 1 | 9th July 2007 09:32 |
| HU ---> Sound | panky12345 | Ask the Gurus | 18 | 28th July 2006 11:34 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446
