Old 7th December 2010, 12:43   #1
nanu28's Avatar
Thanked: 59 Times
Default Fluttering Sound from Octavia 1.8 Turbo
I have noticed a fluttering kinda sound from the car. Its a Skoda 1.8TPi, using the same internals as the vRS. It is from somewhere in the front, it is more prominent on lower revs, and in lower gears, but otherwise also it is there, I am not sure as to what it might be at all, I am totally confused, is it a broken DV, or is my turbo pipe leaking, os is it some belt, I cant figure it out. I first noticed it a few weeks ago After an incident with my intake pipe : The intake pipe had come off just before the intercooler on a drive to Goa, Skoda Goa fixed a new clamp for 150/- and I was all good to go. After that it has been fluttering. I intend to take it and get it checked soon, but I doubt any thing would come up in the Computer.
Any heads up on the issue would really help...
Thanks a lot.
Nanu
nanu28 is offline   Reply With Quote
Old 7th December 2010, 23:41   #2
Thanked: 658 Times
Any pickup issue you are facing.
I suspect the plumbing. but its hard to say just by reading what you have mentioned.
Old 8th December 2010, 15:14   #3
Thanked: 63 Times
Default Re: Fluttering Sound from Octavia 1.8 Turbo
I am almost certain that the vRS and 1.8TPI do NOT have an intercooler. Can you post a picture of which pipe had come off?
Bomi is offline   Reply With Quote
Old 9th December 2010, 12:51   #4
nanu28's Avatar
Thanked: 59 Times
....The inter-cooler is located behind the black plastic cover in the lower front bumper, on the drivers side. Have a look at any vRS or TPI, just pull out the Black plastic cover and you will notice a duct towards the InterCooler.
No I dont think I feel any pick up issue. The turbo whine, is there as always but there is a little flutter in it...
Old 10th December 2010, 10:32   #5
Thanked: 89,145 Times
Nanu, it's 100% to do with the intake. I had a mild fluttering sound after the K&N install too. Played around with the parts (remove & refit) and its gone. You need to take a look at the pipe that Skoda fitted back for you.
I believe they do.
Old 3rd January 2011, 12:52   #6
nanu28's Avatar
Thanked: 59 Times
....The disgonastics and the mech, point it to the EGR Vave...Exhaust Gas Regulator Valve or whatever. Any one has any idea about it for the this engine?
I need to replace that I think. I better be sure before i do anything though.
Old 4th January 2011, 23:47   #7
Thanked: 658 Times
EGR is a pollution control device. Its a expensive piece of equipment.
Disable it with the help of a smart mechanic.
Audi's Sound Concept cabin defines auditory excess: 62 speaker surround-sound ! dar3dev|l In-Car Entertainment 10 22nd June 2010 15:23
Škoda Auto Reveals New Faces Of Octavia Rs And Octavia Scout madhokritesh The International Automotive Scene 12 29th April 2009 16:05
Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? DieselFan Technical Stuff 4 25th January 2008 18:31
strange fluttering sound in my baleno abhishek_rait Technical Stuff 15 29th June 2007 19:01
Cant afford a Turbo? Buy JUST the sound GTO Modifications & Accessories 15 7th January 2006 17:03
