Old 3rd November 2009, 14:01   #121
devrajman's Avatar
Thanked: 116 Times
What about the existing rust? Do they remove all underbody rust and then do the treatment?
devrajman is offline   Reply With Quote
Old 3rd November 2009, 14:11   #122
sgiitk's Avatar
Thanked: 3,866 Times
Infractions: 0/1 (4)
These are preventive treatments. They may remove existing rust as a favour to you. Also, ideally after removal the surface should be passivated (Phosphoric Acid) and coated with primer before treatment. The treatments are best done on a brand new car.
Old 3rd November 2009, 15:00   #123
Thanked: 23 Times
Originally Posted by s3va View Post
I was quoted 3750+10% VAT for 3M under body anti-rust coating with 5yr warranty, for my Chevy Aveo 1.4 that I am taking delivery today.
I got the 3M under body treatment (5yr warranty) on my Aveo for 4000 including taxes.
I think it does some road noise reduction as well.
black_panther is offline   Reply With Quote
Old 3rd November 2009, 16:13   #124
devrajman's Avatar
Thanked: 116 Times
Then whats the best procedure for not-so-very new cars with rust in their underbody?
Old 3rd November 2009, 16:19   #125
gpa
gpa's Avatar
Thanked: 281 Times
You are right! they are best done on a brand new car preferable before taking delivery. There have been cases where the coating has started to peel off when done on cars that are a few months old.
PS: Congrats on becoming a Senior!
gpa
Old 9th November 2009, 18:26   #126
Default Alto LXI under body is getting rusted
I own an ALTO LXI 2005 and bought it second hand couple of years back and lately been observing that it's underbody is corroding faster. My only worry is if some of the supporting stuffs underneath gets weaker and might lead to problems. Also for change of wheels, nowadays i cant fix my jack on the support underneath my door, it is coming of in chips. Does anyone how can i avoid further deterioration.
Soumya_Ramesh is offline   Reply With Quote
Old 9th November 2009, 19:17   #127
amit_mechengg's Avatar
Thanked: 1,556 Times
get a underbody antirust coating done of a reputed brand. 3M is a good one.
Old 9th November 2009, 19:21   #128
MutantX's Avatar
Thanked: 89 Times
well, you need to get your underbody fixed first. I suggest you take it to MASS and ask if the chipped portol can be welded first. Once that is done, you can do in for the 3M anti rust coating.
If MASS quotes exorbitant prices! then chuck it and get your self a good local mechanic who can help for welding or correcting the rusted parts first.
MutantX is offline   Reply With Quote
Old 15th November 2009, 17:23   #129
Gandhi's Avatar
Thanked: 203 Times
Question
Guys, I have booked a Black Ritz Zxi. The accessories guy at the dealership is recommending Teflon coating and Underbody anti-rust treatment. The teflon coating is from Dupont worth 4000/- and underbody treatment is worth 4500/- (forgot to ask about brand). As I have booked a new car, he has offered a 10% discount (after tax) and 2000/- flat discount on total bill.
Please suggest if I should go for it or not. I have read here that teflon coating is not required, but underbody treatment is good for the car in long run.
Gandhi is offline   Reply With Quote
Old 15th November 2009, 19:48   #130
knp
Thanked: 18 Times
Hi Gandhi, I think that you can go for the underbody treatment, as even I had gone for that for my i10 from the dealer. I had paid around 2300/- after discount. Teflon is not required.
knp is offline   Reply With Quote
Old 15th November 2009, 20:03   #131
Gandhi's Avatar
Thanked: 203 Times
Do you remember the brand of underbody treatment you got for your i10? What is the warranty period?
Old 15th November 2009, 20:10   #132
DieselFan's Avatar
Thanked: 234 Times
Both Teflon coating and underboady treatment are not mandatory as Bangalore is not as corrosive as Chennai or Mumbai for underboady treatment. Teflon coating is totally a con job of the authoised Service center. Not required at all. All maruti cars come with clear coat paint which is similar to teflon coating.
DieselFan is offline   Reply With Quote
Old 15th November 2009, 21:01   #133
greenhorn's Avatar
Thanked: 1,508 Times
gandhi, you might want to check this thread too
http://www.team-bhp.com/forum/techni...-new-cars.html (Teflon Coating - Harmful on new cars?)
Old 15th November 2009, 21:14   #134
Gandhi's Avatar
Thanked: 203 Times
Originally Posted by greenhorn View Post
Thanks. That's where I had read that teflon coating is not required. Still not decided on the underbody treatment.
Old 16th November 2009, 08:41   #135
knp
Thanked: 18 Times
It's 3M with 5 years warranty.
DIY: Anti-rust treatment for a Gypsy antihero DIY - Do it yourself 24 22nd April 2015 21:27
Anti honda?? Anti suzi?? Anti fiat?? Anti ford etc etc?? Vent out ur opinions here!!! mclaren1885 Shifting gears 3 29th June 2006 14:23
How important is anti-rust coating? Zappo Modifications & Accessories 8 7th January 2006 01:54
