Old 10th December 2010, 18:17   #1
greenhorn's Avatar
Thanked: 1,519 Times
Default Cracked Belt Cover
I opened the hood to notice today that the (timing?) belt cover seems to be cracked. Hadnt noticed it till now. Not planning to drive any more except to take it for service. Just curious if this has any impact on the belt life etc
greenhorn is online now   Reply With Quote
Old 10th December 2010, 19:04   #2
planet_rocker's Avatar
Thanked: 368 Times
Default Re: Cracked Belt Cover
if the belt cover is fouling with the timing belt then that is not good news. if not then it can safely be driven to the work shop.
what were your friends doing when they were driving your car to BBSR?
planet_rocker is offline   Reply With Quote
Old 10th December 2010, 19:33   #3
greenhorn's Avatar
there are some weird noises and clatter at some speeds, and the Check Engine light now almost a regular feature. but the car is very driveable, and I wouldn't have even noticed.
They said they were trailing lorries at night due to the abysmal high beam, and consequently fell into almost every pothole along the way. The internals seem to have taken a good beating :|
Old 11th December 2010, 11:46   #4
anky's Avatar
Thanked: 107 Times
Default Having same type problem in my dads indigo dicor
Hi my dads indigo dicor belt suddenly makes a squeaking noise and the engine rpm drops to 400 instead of the regular 800 - 1000 rpm. I dont know which belt makes the noise will have to give car for service soon as possible as it scary to drive like this.
anky is offline   Reply With Quote
Old 11th December 2010, 13:17   #5
greenhorn's Avatar
thats probably the alternator belt. happens all the time, if the squeaking doesnt go away after some time, you might need to have it tightened.
Old 11th December 2010, 14:02   #6
Thanked: 149 Times
Check engine light coming on frequently is not a good sign. Just call the service center and ask them to come and have a look before starting the engine. Hope you know what you mean when you say it is the timing belt cover.
On second thought, is not the timing belt inside the engine? Can such a critical part be put in an easily openable enclosure?
Old 11th December 2010, 14:31   #7
jav
That is definitely the timing belt cover and it has "warped" due to heat i guess, the gap in my car is so wide i can see the timing belt clearly, had to stick tape over it to close the gap
jav is offline   Reply With Quote
Old 11th December 2010, 15:09   #8
greenhorn's Avatar
they asked me to not drive it much, and gave me a date on the 15th. I found this when i opened the hood to check for any loose connections which might be causing the CEL . its broken, if you notice the top part of it has broken and come loose from the place where it was fixed.
Old 12th December 2010, 22:24   #9
Thanked: 660 Times
Well they are right. You know what, while rebuilding engines, this is one are that takes lot of time to re-calibrate.
Get it changed asap. How much has the car run BTW?
alternator belt damages timing belt??? jalsa777 Technical Stuff 21 8th March 2015 10:52
Cracked induction pipe 16v100bhp Technical Stuff 0 24th December 2006 09:28
HELP!!: Hit a Stone/cement block cracked a RIM & busted a tyre aZa Tyre & Alloy wheel Section 11 15th October 2006 12:24
Cracked Windshield - Advise needed Vivek Technical Stuff 1 17th June 2005 20:43
Windshield cracked in Indigo TheBrainCell The Indian Car Scene 5 3rd July 2004 12:21
