Old 14th December 2010, 22:27   #1
Thanked: 36 Times
Default New Fiesta 1.6S friction-like noise at around 1200rpm
Guys
Just today, after reaching back home and having a listen to my ICE system, I noticed this strange noise that came when I revved the engine. The noise comes continuously between 1000 to 1250rpm and then everything is smooth.
No matter how I rev it, it is this band where the noise comes. There is no noise when there is no throttle input (900rpm) it is felt and hear just between 1000 to 1250rpm after which it is butter smooth.
And even when I rev the engine to say 4000rpm and lift off the throttle, as and when the rpm comes down and reaches this band, the noise is heard just the same way, no perceptible change in loudness or anything.
If I keep the revs exactly in this band, the noise is there continuously.
The noise is almost like some kind of "resistance" or "friction" from somewhere inside the bonnet but that is highly unlikely as the car has just completed 5000Km and the first service was done a fortnight ago due to which there is a tremendous increase in fuel efficiency.
It sounds like "grrrrrr" and I can even feel it through my feet.
I am losing my sleep over it, please help me guys.
Best of regards
abhipuru16 is offline   Reply With Quote
Old 15th December 2010, 06:10   #2
Thanked: 128 Times
Default Re: New Fiesta 1.6S friction-like noise at around 1200rpm
From my limited knowledge, some degree of vibration is normal for a 4 cyl car engine.(6 cyl configuration is said to be most balanced) It becomes perceptible usually in no load condition (revving in neutral)
I have noticed the same in my SX4 as well.
If you are worried check another Fiesta 1.6, so that your doubts are cleared.
sureshkishore is offline   Reply With Quote
Old 15th December 2010, 07:41   #3
ghodlur's Avatar
Thanked: 2,438 Times
Red face Re: New Fiesta 1.6S friction-like noise at around 1200rpm
Better show it to the service centre. You dont want something to be causing friction for long which may result in some damage.
I hope you would be able to recreate the same conditions to show the advisor the issue.
ghodlur is online now   Reply With Quote
Old 15th December 2010, 08:39   #4
kiku007's Avatar
Thanked: 1,482 Times
Let me break it down further,
1. It sounds similar to belt noise
2. When the car revs down, you hear this noise typically at 1200 rpmish?
3. Open the bonnet, ask someone to rev the engine in this rev range and try to source the noise from the engine bay. It's from say, bang in front of the driver's side.
If it's all the above, then welcome.
I also faced/face the same issue. First they changed the coolant saying they have to use level2 coolant (I don't believe); didn't fix. Then they changed the water pump;temporarily, partially fixed. Now it's back in it's full form. Have to take my car back to the workshop when I have time.
Will keep you posted. Meanwhile why don't you raise this issue through the customer care?
kiku007 is offline   Reply With Quote
Old 15th December 2010, 12:57   #5
Thanked: 36 Times
2. When the car revs down, you hear this noise typically at 1200 rpmish? See, let's put it this way- I hear it from 1000 to 1250rpm and 1250 to 1000rpm. Within this 250rpm there is no change in tone or loudness, it is a "one note" noise in this band of rpm.
3. Open the bonnet, ask someone to rev the engine in this rev range and try to source the noise from the engine bay. It's from say, bang in front of the driver's side. Will try it today.
Which car do you own?
Old 15th December 2010, 19:13   #6
kiku007's Avatar
It's a 2009 Dec Fiesta 1.6.
Old 15th December 2010, 19:32   #7
amit_mechengg's Avatar
Thanked: 1,556 Times
is it the hissing sound when you listen to the music only? what happens in the same rpm when music system is switched off? i was thinking about alternator whine.
Old 16th December 2010, 16:11   #8
Thanked: 36 Times
No No, it is not alternator whine.
This "rubbing-grinding" noise is definitely from somewhere under the hood as I could make out after listening to it carefully yesterday.
Old 18th December 2010, 01:43   #9
Thanked: 36 Times
Today, the car came back home in the evening after a long drive spanning 70Km. Just before reaching home, it was tanked up to the brim.
Now, as soon as it came home I checked for that same vibration but surprisingly, there was no vibration this time around! It was just like new, smooth and cream-like revving
What do I make of this? Good Fuel? Optimum Engine Temperature i.e., a nicely warmed up Engine?
Clutch friction plate hub shaking: Root cause? dhanushs Technical Stuff 32 15th December 2015 20:13
Friction Modifier for LSD suman Technical Stuff 12 8th August 2014 14:21
Magnetic Non Friction brakes, could it be the future? Shan2nu Technical Stuff 2 12th February 2010 15:11
Please help me decide: Fiesta S or Fiesta ZXi? EDIT: Booked Fiesta S! Pics on pg5. frankmehta Sedans 108 18th August 2009 13:43
