Old 16th December 2010, 23:43   #1
A.R
A.R's Avatar
Default Maruti Baleno stranded!
Note from the Team-BHP Support : SMS / Slang is STRICTLY prohibited on this community. We would much appreciate your using full & proper English in posts, for the benefit of other forum users.
Please view our board rules carefully before proceeding any further.
guys, need urgent help. while travelling to kollur off nh17 , i had slightly get off the road to avoid an oncoming bus, stopped n the car wudnt move. To describe the issue: car turns on, clutch can be depressed , all gears engage, but car does not move. there is a katrrrrrrrrrrrrrrrrrrr sound when i try to accelerate. not sure if its coz of the terrain.
car is now parked waiting to be towed to a nearby Maruti service center tomorow morning. Maruti online service n nearby masc refused to help today since it was past 6pm! any help towards identify what cud have probably gone wrong would help. also some help on which maruti service center to go to wud help coz not all masc wud have parts for a baleno, me thinks.
A.R is offline   Reply With Quote Received Infraction
Old 16th December 2010, 23:58   #2
Hashim's Avatar
Thanked: 32 Times
Default Re: Urgent help: baleno stranded
I think one of the drive shaft (left or right) is broken. Replacing the drive shaft should not take more than an hour if nothing else is gone wrong. Whichever is broken, get both replaced if they are old.
Hashim is offline   Reply With Quote
Old 17th December 2010, 00:02   #3
Thanked: 128 Times
The Driveshaft must have broken. The milling on the shaft has know to fail. Earlier Reported cases can be refered
http://www.team-bhp.com/forum/techni...e-9k-more.html (Baleno issue : Could a stitch in time have saved me 9K or more ?)
http://www.team-bhp.com/forum/techni...ft-baleno.html (Drive shaft for Baleno)
sureshkishore is offline   Reply With Quote
Old 17th December 2010, 10:05   #4
aaggoswami's Avatar
Thanked: 1,542 Times
Mostly the problem is broken driveshaft/s. Any one broken driveshaft will lead to open differential and the car wont move.
How many kms. the car has covered ?
Generally before failure, driveshaft would lead to some noise like kat..kat specially in turns. That the time when one has to replace the drive shafts.
aaggoswami is offline   Reply With Quote
Old 17th December 2010, 16:00   #5
A.R
A.R's Avatar
just got it checked at a private garage,right drive shaft gone. Now another problem - no part available in an around mangalore. Where do i find the part pls?
Old 17th December 2010, 18:16   #6
supremeBaleno's Avatar
Thanked: 1,711 Times
Exact same issue as I faced some months ago with my Baleno. As others mentioned, the drive shaft is kaput. How old is your car BTW ?
Originally Posted by sureshkishore
This link is about the issue I faced. For a supposedly top-end offering, the quality seems to be crappy. It was around 15 years after which I replaced the drive-shaft on my 1985 M800. With the Baleno, the part was gone after just 5 years.
Old 17th December 2010, 18:57   #7
A.R
A.R's Avatar
got vehicle towed to kamath motors, mangalore, they did some workaround by welding/lathe to existing driveshaft. the service engineer is currently testing car...says ok to drive to blore slowly. else will have to wait for 4-5 days. blore service centers have the parts.
Old 17th December 2010, 21:07   #8
gd1418's Avatar
Thanked: 656 Times
A suggestion if you drive to B'lore with this repaired drive shaft - avoid going into any kind of potholes, depressions like plague, especially on the right side.
And in B'lore when you replace, replace both. And while doing so, ask them to service the steering assembly as well.
Old 17th December 2010, 22:29   #9
A.R
A.R's Avatar
thanks folks for the help. will be leavin mangalore tomorow morning to blore, didn't want to risk driving at night.hope things go well
Old 17th December 2010, 22:31   #10
Eddy's Avatar
Thanked: 5,078 Times
^^ Better keep numbers of the service stations and a couple of tow trucks enroute handy
Eddy is offline   Reply With Quote
Old 18th December 2010, 20:24   #11
IndigoXLGrandDi's Avatar
Thanked: 161 Times
@hashim and gd1418,
Why to replace both drive shafts when only one is damaged?
I have replaced the left drive shaft of Indigo LS (May 2004) at around 1,80,000-1,85,000kms (dont remember exact reading). Now the reading is 2,09,000+kms.
The car was bought Brand New.
Mostly the left drive shaft gets damaged since the left side has to get down the road if an OverSmart Oncoming Vehicle comes.
The Rubber Boot of that Drive Shaft (left) has got torn (I had bought from local spare part shop since the price difference was around 2500/-. Local Garage Price--3900-4000/- TASS Price--6500/- ).
I will replace the Boot.
IndigoXLGrandDi is offline   Reply With Quote
Old 20th December 2010, 03:13   #12
Thanked: 157 Times
On our Maruti 800 the CV joints lasted only 38000 kms while with Baleno bot the Driveshafts and CV joints wok fine at 70k kms.
Buffetfan is offline   Reply With Quote
Has your Car ever got stuck / stranded? Where & How? n.devdath Street Experiences 39 9th June 2016 11:53
Helping fellow BHPians stranded on road. navrddy Street Experiences 18 16th September 2011 23:28
Emergency... Innova Overheating!!! Parents Stranded near Krishnagiri. Archish Technical Stuff 30 30th March 2010 18:11
Stranded - the electronic way!! (Engine cut-out by Security System) neel385 Modifications & Accessories 9 24th June 2009 22:59
Have you ever been Stranded on Highway with your car and with family? muke31 Street Experiences 21 30th April 2009 15:57
