Old 21st December 2010, 15:21   #16
Speed Pujari's Avatar
Thanked: 389 Times
Default Re: Hand slipping over the steering wheel
I had exactly similar issue in my Palio.
Got the whole steering leather done at Stanley. Paid 2k+. No problem of slipping till date.
Ask for the soft leather ones, the price is slightly higher than the stiffer ones.
Speed Pujari is offline   Reply With Quote
Old 21st December 2010, 18:48   #17
RemingtonSteele's Avatar
Thanked: 170 Times
Originally Posted by anilisanil View Post
as someone mention it also may be due to the dashboard polish applied to steering wheel. Carnation applied dashboard polish to steering wheel, any idea how to get rid of that?
Dampen an ordinary turkish towel in warm water (I repeat warm water - not hot water) and rub your stearing along the circumference.
RemingtonSteele is offline   Reply With Quote
Old 21st December 2010, 21:09   #18
Abes's Avatar
Thanked: 57 Times
Doesn't the air con mitigate the sweating issue?
I always drive with the a/c on, whether its hot or cold. It also prevents dust getting inside the cabin, which is my concern!
Abes is offline   Reply With Quote
Old 21st December 2010, 21:46   #19
Thanked: 113 Times
I face the same problem with sweaty palms. Talcum power is one idea I plan to try. Waiting ot fix a leather steering grip - either Karlsson or Pensee or if Stanley has handstitched (not laced), will check.
Is 2K too much for 1.3mm leather hand stitched?
Ragul is offline   Reply With Quote
Old 21st December 2010, 22:13   #20
amit_mechengg's Avatar
Thanked: 1,556 Times
take colin and apply to the steering wheel. the dashboard polish put on steering can be removed this way.
Clutch slipping and hot AC 2parag Technical Stuff 13 20th May 2016 17:07
All wheel steering vs front wheel steering SamtheLeo Technical Stuff 17 28th July 2009 20:11
Gear slipping to neutral? - Wagon R johy Technical Stuff 32 25th March 2008 19:01
Can you avoid slipping the clutch during reverse ? meerkat Technical Stuff 7 6th June 2006 11:35
