Old 21st December 2010, 19:33   #1
Exclamation Wagon R - Not able to configure remote locking.
I have Maruti Wagon R (old Gen); i have installed Nippon NCS 405/505 Central locking.
It is working fine.
But funny thing, is it unlocks itself when ignition is turned off (like in traffic signals) and doors release mechanism is unlocked.
How to configure, such that doors are unlocked only, when key is removed from key cylinder and not when engine is switched-off from running condition (idling).
Experts pl. help.
navrddy is offline   Reply With Quote
Old 21st December 2010, 19:59   #2
jeeva's Avatar
Thanked: 230 Times
Default Re: Not able to configure remote locking.
Nothing funny about it.
That's how its supposed to work.
jeeva is offline   (1) Thanks Reply With Quote
Old 21st December 2010, 21:42   #3
gautamkhadse's Avatar
Thanked: 51 Times
+1 to Jeeva : The remote locking works the same way . It unlocks as soon as you turn off the engine . Am not very sure if it works the same way on OEM security systems . My dad drivers a montero and it works the same way in that .
gautamkhadse is offline   Reply With Quote
Old 21st December 2010, 22:48   #4
libranof1987's Avatar
Thanked: 768 Times
That's how it is meant to be. The moment you turn off the engine, the remote locking is disengaged and the doors are unlocked.
However, if you turn the key and keep it at ignition, within 2-3 seconds, it engages again and the doors will be locked.
I agree it is annoying at signals when you turn the engine off.
To ensure the doors remained locked, I manually locked the driver door (and hence all doors) at signals when the engine was off. When you turn the engine on, the central lock system does a check on whether the doors are locked.
That's the only solution I've come up with.
libranof1987 is offline   Reply With Quote
Old 21st December 2010, 22:49   #5
It unlocks as soon as you switch off the engine and it locks when u turn on the ignition and it stays locked when the car is running
Even autocop works like this
raghav.carfreak is offline   Reply With Quote
Old 23rd December 2010, 05:19   #6
Default Re: Wagon R - Not able to configure remote locking.
But, i heard from my friend. door is unlocked(in santro), only after removing from key cylinder. not switching off the ignition.
In my case(even after i switch of ignition and again turn it on.) doors are not locked only after vehicle reaches certain speed.
Old 23rd December 2010, 16:39   #7
Thanked: 129 Times
I think only some models (higher priced ones) allow this kind of configuration. Mine opens doors as soon as engine is switched off.
Old 27th December 2010, 09:28   #8
bhp_maniac's Avatar
Thanked: 28 Times
I have seen OEM Nippons unlock only after removing key from key cylinder. I have seen Autocop ones which unlock with ignition OFF position. I suggest you check it with MASS. I hope you have got it installed from them I have a Nippon OEM installed on my Swift. It unlocks with key removed from key cylinder. The locking mechanism has two options, one being locking the door after some time and other option is to lock it after the car reaches a specific speed. The configuration mechanisms are provided in the Nippon user manual.
bhp_maniac is offline   Reply With Quote
When Remote Locking Fails adisag Modifications & Accessories 35 9th December 2010 09:14
Remote locking system turns cental locking - key fobs not working - any solutions? ukamath Technical Stuff 10 20th August 2010 20:50
Alto Xcite - Upgrade Manual Central Locking to Remote Central locking Laxminarayan Technical Stuff 1 28th December 2009 14:02
Central locking versus remote locking mb_jg Technical Stuff 40 2nd January 2009 19:08
remote locking gsbhatia Technical Stuff 0 27th October 2008 21:36
