Thread Tools
Old 24th December 2005, 12:21   #1 (permalink)
pratheesh's Avatar
Smile High Octane and Maruti
hi dudes,
its been long time since i posted my stupid questions.
well my query is "whether high ocatne petrol will increase the performance of maruti 800" (i ve heard somewhere that high octane petrol performs well only in high comprssn ratio engines)
and what is the compression ratio of maruti 800?
i ve read in article here, that toluene addition can increase the octane value of petrol, so what is the best octane number for a maruti 800.
in that article it was said that toluene costs about 30rs/ltre, but when i asked a chemical store, they said it costs about 360rs/litre
are there any other methods to increase the octane value of petrol....
please reply
bye,
Pratheesh Prakash
__________________
What it is unique for Indian Cricket Team?
Ans:- The batsmen are good at bowling and the bowlers are good at batting!!!
pratheesh is offline   Reply With Quote
Old 24th December 2005, 18:42   #2 (permalink)
DCEite's Avatar
Hi Pratheesh.
A similar thread exists here : http://www.team-bhp.com/forum/techni...ve+performance (How does high octane fuel improve performance?)
I hope you will find your answers in that post.
The search utility at the top is a great little tool...
DCEite is offline   Reply With Quote
Old 26th December 2005, 02:08   #3 (permalink)
nitrous's Avatar
Purified toluene can be got for 60 bucks a litre.But, lab grade toluene which is used for research is priced at around 300 bucks a litre. I've had bad experiences with toluene blowing up two yamaha 135 cc engines when i mixed to get 100 octane fuel out of 93 octane fuel about 6 months back. I dont know why. So, i'm not against using toluene but i'm warning u about the risk.
__________________
youtube.com/watch?v=FiVicNOA3bY
Old 26th December 2005, 02:38   #4 (permalink)
Godfather's Avatar
you do get octane boosters.. check with performance dealers or i think even STP makes them..
__________________
I accidentally installed the deer whistles on my car backwards. Now everywhere I go, I'm chased by a herd of deer.
Godfather is offline   Reply With Quote
Old 26th December 2005, 03:35   #5 (permalink)
Mpower's Avatar
No, it generally will not. It will only if
  • You increase the compression or advance the timing
  • If you already have a knocking problem for some other reason
__________________
The difference between the men and the boys....................is the speed of their toys.
Mpower is online now   Reply With Quote
Old 1st January 2006, 16:58   #6 (permalink)
pratheesh's Avatar
cheers to xtra premium, i g0t 21 kmpl using xtra premium on a long trip..... no problems for engine so far...!!!
__________________
Old 2nd January 2006, 01:57   #7 (permalink)
nitrous's Avatar
WHOAAA! Did u do the maruti 'mileage challenge' or something??
Pls tell us more about ur car. Is it mpfi or carb?? Did u get this figure with ac on/off? How did u check the mileage??
__________________
Old 2nd January 2006, 16:54   #8 (permalink)
pratheesh's Avatar
Smile
carburettor.....travelled in between 60-80 kmph, without ac.
fuelled 12.55 litres of xtra premium, and checked the meter it was *414 (before fuelling the tank was almost empty, the pointer was just below the 'E') and just before the next refuel i checked and the reading was *678 (at this time the pointer was exactly at "E")
and the rest is mathematics,.....
infact my engine overheated during the trip (my radiator was empty) , else the mileage would have been more than 22 kmpl......
cheers to high octane
now my goal is to prepare my own high ocatne and nitrous i need your VALUABLE opinion...
yours,
pratheesh prakash
__________________
Old 2nd January 2006, 18:24   #9 (permalink)
shuvc's Avatar
Did you top up after at the end of the trip ? i.e. when the reading was *678 ?
__________________
PIGZILNKILJBSCOMB
Old 2nd January 2006, 20:57   #10 (permalink)
.anshuman's Avatar
normal 87octane petrol is what a maruti 800 is tuned for.
__________________
HR 26 X 786
Old 7th January 2006, 17:40   #11 (permalink)
pratheesh's Avatar
Smile
oops! i didnt get you (I AM STUPID), if you mean filling the tank i didnt do that, and please tell me the necessity of doing so...
well though M800 is tuned for 87 octane, my car knocked at low speeds. but when i used xtra premium, i was able to travel at low speeds without shifting the gear down. I think that might have helped to achieve this mileage...
and also another guy using the mpfi 5gear version (new one) of M800 got 21kmpl (i dont remember his name, i think it is adit, look for more in the car review section : http://www.team-bhp.com/forum/new-ca...tml#post161642 )...
i dont think the result i got was wrong.... and still i am using Xtra premium....
well nitrous, please tell me what all precautions you should take when mixing our own high octane petrol...
thanks...
Pratheesh Prakash
__________________
Old 9th January 2006, 15:59   #12 (permalink)
But you say your pointer was below E when you filled up (12.55Ltr) and when you calculated mileage your pointer was at 'E'.
How do you know exactly how much fuel difference is there between "below E and E", and if you do did you take this into account ?
Best method to calculate FE (than reading needles from fuel guage) is - say your needle is halfway (can be anywhere!) you fill up tank completely. (Ask the guy filling to stop when the fuel nozzle sensor stops first-time). Take the start reading (x414 in your case) - Next time you go fuel your car (again say halfway needle) and now you top up (full tank like above) again. Say this time 10 ltr fuel went in, you check the odo, now you have final km (- initial km/10 = your mileage)
Sorry if you are aware of above and did your testing correctly and I am being too pedantic , but just that 21 sounds like a figure too high.
__________________
2005 Tata Indica LGi
Abhay is offline   Reply With Quote
Old 9th January 2006, 16:26   #13 (permalink)
speedsatya's Avatar
yeah the best way to calculate FE is tank up the car fully and then drive till the half tank level and then tank up again...then use mathematics...the one that you have used can have errors ...but still you have got good FE...cheers ...
go to the FE thread and you will see that many of our cars have given better FE
speedsatya is offline   Reply With Quote
Old 9th January 2006, 16:46   #14 (permalink)
prkothan's Avatar
21 kmpl is not a big deal for m800 or zen or esteem. I got 18kmpl with AC in my Palio 1.2 (OV) in highway travel (Tambaram to villupuram).
prkothan is offline   Reply With Quote
Old 9th January 2006, 18:33   #15 (permalink)
n_aditya's Avatar
maruti 800 is one of the most FE cars around... i happen to also own a 4 geared MPFI version NON AC, and i get b/w 16 and 18 in city and b/w 21 and 23 on highways.... all on regular unleaded fuel....
all it needs is timely service and some love...
Thread Tools
How does high octane fuel improve performance? DCEite Technical Stuff 90 19th June 2008 11:53
Are High Octanes really high OCTANE pratheesh Technical Stuff 9 20th September 2006 22:48
premium diesels do they work like high octane petrol garvit2002 Technical Stuff 2 20th February 2006 09:54
High Octane Fuel Domnic A Collection of the best threads 88 27th October 2005 15:34
High Octane for NHC? srasania Technical Stuff 6 28th May 2005 20:24
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
