View Poll Results: Do you feel that a car feels more responsive while driving at night?
Yes, the car definitely feels quicker at night 27 90.00%
No dude, you are imagining things. 3 10.00%
Voters: 30. You may not vote on this poll
Old 28th December 2010, 13:07   #16
praful's Avatar
Thanked: 436 Times
Default re: Ah, winter time. Engines are feeling better due to cooler air!
Engines perform better in colder weather. Primary reason : The density of cool air is a lot more than hot air. Thus, you end up with a superior burn, which results in better performance & efficiency.
Pardon me for the noob physics doubt!
But denser air also means more drag right?
So shouldn't there be any difference on performance and efficiency as the body of the car has to work harder to overcome wind resistance?
praful is offline   Reply With Quote
Old 28th December 2010, 13:08   #17
Thanked: 13 Times
Not any noticable change in throttle response, but yes - definately better FE figures in winters since AC use is minimized.
jigbarai is offline   Reply With Quote
Old 28th December 2010, 13:47   #18
JayD's Avatar
Thanked: 1,996 Times
Over the winter season, I've noticed a distinctly sharper throttle (compared to the harsh summers), the engine seems smoother and revv-happier. This effect is even more pronounced with diesels (especially the Jeep). It is around this premise that the cold-air-intake industry exists, and whatever the season, your engine will feel sharper at night than at noon.
Are you feeling it?
Yep! My intake air temps are down to the 25 range, from 40 plus usually. Even in the evenings i'm pulling in 31-33 from the normal 50+. Response seems a lil better, and FE is showing a massive increase!(Another factor is that i don't use the A/C much now) Overall, I'm loving it.
Old 28th December 2010, 14:29   #19
ask77's Avatar
yes ! especially here in the north where the temperature difference between summers and winters is huge there is a very perceptible difference in engine performance. The engine is much smoother , there is much less engine noise although that may be because the radiator fans are running lot less and of course the FE is much better because the a/c is not running and you can actually switch off the engine on a red light !
ask77 is offline   Reply With Quote
Old 28th December 2010, 14:35   #20
Thanked: 161 Times
Originally Posted by akshay4587 View Post
I am sure,most of us idle cars,till the RPM settles down to normal.
I have a question and I think it is related to the thread. When I start my car in the morning (ambient temperature is about 15 degrees, say), idling rpm is more than 1.5K, actually quite close to 2K. Within a few seconds (at most 5 seconds) of idling, the rpm comes quickly down to about 1.1K and stays there. This is when I usually start moving. The normal idling speed after a full warm-up is about 900 which is attained after a few minutes of driving (I try not to cross 2.5K during this period). Is it necessary to idle the car to the point when the fully normal idling speed is achieved? I thought cars of this generation did not need an elaborate warm-up, apart from the initial few seconds. Is my thinking wrong?
asitkde is offline   Reply With Quote
Old 28th December 2010, 14:36   #21
SS-Traveller's Avatar
Thanked: 10,862 Times
It's not THAT dense!!!
Denser air = more oxygen in it = better fuel burn.
Old 28th December 2010, 23:17   #22
dhanushs's Avatar
Thanked: 4,057 Times
True! but for drag to show its effects on FE, you should be traveling well above triple digit speeds all the time.
(Windows down or A/C on -- which is more fuel-efficient?)Windows down or A/C on might give you some insight.
Old 28th December 2010, 23:27   #23
mercedised's Avatar
Thanked: 160 Times
Engine runs cooler, this also has a effect on the better engine feel. Just like night driving, one might consider,as if, we drive all the time as in night, in winter. (lol.. )
mercedised is online now   Reply With Quote
Old 28th December 2010, 23:50   #24
.anshuman's Avatar
Thanked: 9,025 Times
The Laura manual clearly states that the Engine when cold does return a very low FE until it warms up. Up here in the North where we have shivering cold winters, the Diesel engine takes forever to warm up, until then it sounds crude irrespective of the make.
But Yes after they warm up the performance is a lot better thank to the FREE cold air intake for some months. FE is also better thanks to the reduced AC usage.
Old 29th December 2010, 00:23   #25
Technocrat's Avatar
Thanked: 2,492 Times
Yes, I have noticed this both in my bikes & car in Pune. The engine runs smoother & the FE is more.
But yes when it gets very low, it takes some time for the engine to come to the ambient operating temperature before it can perform well.
Old 29th December 2010, 01:11   #26
shuvc's Avatar
Thanked: 283 Times
In places where temperatures drop below say 10 or 5 deg, what effect does the cooler air have on cars fitted with cold air intakes? Would it further cool down the intake air?
shuvc is online now   Reply With Quote
Old 29th December 2010, 01:35   #27
Hashim's Avatar
Thanked: 32 Times
Yes I am feeling better performance from my car too.. much better throttle response even in LPG and lesser down shift of gears. I know as I travel from same road everyday and my hands almost know instantly which gear to put at which turn, but now car stays in power band and it does not knock. Only trouble is getting it idle properly first time in morning, thanks to age of the car and weak ignition system. Although it starts with a single click of the key but doesn't idle when started cold in morning. Rest of the day its fine.
Hashim is offline   Reply With Quote
Old 29th December 2010, 02:47   #28
khoj's Avatar
Thanked: 1,253 Times
Originally Posted by asitkde View Post
I have a question Is it necessary to idle the car to the point when the fully normal idling speed is achieved? I thought cars of this generation did not need an elaborate warm-up, apart from the initial few seconds. Is my thinking wrong?
Well, what you are doing is quite acceptable. If you could wait till the engine attains its normal idling speed that would be ideal but is not essential.
As for the current generation of engines they are still made up of metallic bits and different kinds at that. You want all of the different bits to have attained a working temp before you load them up and it is always best to have metal running against metal with a bit of hot lube in between them. So while a warm up is still desire-able, modern day metallurgy & chemistry have ensured that the time taken to warm up now a days is much much shorter than what the engines of yore used to take.
Old 29th December 2010, 17:14   #29
Thanked: 89,462 Times
What you have in Mumbai is hardly winter - I know friends who swim even in December!!
So true. But 20 degrees is better than the 45 of summer
The fuel density is also higher, the AC is turned off (no/minimal compressor load), and the engine oil maintains its viscosity better in cold weather. Result: The engine sounds more silent, revs more easily once warmed up, and gives better FE. My Scorpio returns about 1.5 km/l more, and the Swift about 2 km/l more than in summers.
Thanks for sharing the additional points. Very insightful post.
I would think so. However cold the outside air, the engine bay will always be warmer / hotter.
Old 29th December 2010, 17:40   #30
driving_smartly's Avatar
Thanked: 211 Times
Is it Advisable to keep engine Idle till the temperature guage shows that engine has warmed up. I did this recently before my visit to my native place, the ride was smooth throughout. Filled the tank full, then did 363 kms (Return) with almost 60% AC. My Santro took 19.27 litres cutoff at petrol bunk. An average of 18.84 kms per litre with 4 passengers and luggage. Speed was maintained between 80-100. Though i had driven very sedately but still i had to accelerate heavily in 3 ghats for overtaking
driving_smartly is offline   Reply With Quote
Please suggest good Air Cooler Max Gadgets, Computers & Software 97 25th April 2017 14:28
2015 MotoGP Safety Car - BMW M4 with water injection system for cooler (intake) air syedhafeez The International Automotive Scene 0 17th February 2015 02:52
can you add Glove box cooler in car mrkanitkar Modifications & Accessories 12 22nd July 2010 00:28
Do non-common-rail diesel engines work better with warm air? Samurai Technical Stuff 35 23rd January 2010 09:34
Is car performance without safety systems better - due to less load on ECU? vibhu_f430 Technical Stuff 7 17th March 2008 00:04
