View Poll Results: Do you feel that a car feels more responsive while driving at night?
Yes, the car definitely feels quicker at night 27 90.00%
No dude, you are imagining things. 3 10.00%
Voters: 30. You may not vote on this poll
Old 4th June 2011, 01:46   #91
dhanushs's Avatar
Thanked: 4,055 Times
Default Re: Monsoons improve Mileage....
Only one reason: Monsoons = Denser air
Old 4th June 2011, 01:51   #92
Thanked: 7 Times
In USA i get lower mileage in winter.. weird its quite opposite there..
Ford_madhan is offline   Reply With Quote
Old 4th June 2011, 06:29   #93
TOR
TOR's Avatar
Thanked: 20 Times
Yes that correct. This will be 'sensed' by the ECU thereby altering the combustion mixture leading on to better efficiency.
The need for less amount of AC and (in my experience) less traffic on the whole(due to lac of two wheelers) on the roads contribute to a certain extend.
TOR is offline   Reply With Quote
Old 4th June 2011, 12:20   #94
silverado's Avatar
Thanked: 636 Times
@clevermax
Lower rolling resistance due to water on roads.
silverado is offline   Reply With Quote
Old 21st November 2011, 14:32   #95
bluevolt's Avatar
Thanked: 2,211 Times
Default re: Ah, winter time. Engines are feeling better due to cooler air!
The minimum temperature has reached around 14 degrees in NCR and I am already noticing change in engine operation in terms of mileage and smoothness. I am getting around 2 KMPL more mileage from all my cars and bikes and engines are revving more smoothly.
bluevolt is offline   Reply With Quote
Old 9th December 2011, 12:28   #96
goandude's Avatar
Thanked: 437 Times
Originally Posted by silverado View Post
@clevermax
In fact rolling resistance increases with water (or anything else) on the road, as the tyres have to pump the water out.
goandude is offline   Reply With Quote
Old 9th December 2011, 12:35   #97
swarnava.m's Avatar
Thanked: 256 Times
Hardly. Here in Goa, there is not much of a difference in the temperatures between May and December. Hence for us folks, its all the same.
The only thing I have noticed is, yes, the engine does feel sharper at night that at noon. For these reasons I sometimes wish I stayed somewhere more inwards.. And happily hear my car gurgling with pleasure in the Winter.
swarnava.m is offline   Reply With Quote
Old 9th December 2011, 13:26   #98
greenhorn's Avatar
Thanked: 1,318 Times
Yup, totally agree, especially for those of us with Turbodiesels. The car feels just as nice all day (instead of becoming sluggish in the afternoons)!
The only fly in the ointment is that the windows tend to fog up at night, and the AC feels too cold.
Old 17th December 2011, 01:12   #99
silverado's Avatar
Thanked: 636 Times
If thats the case why do we get better braking performance in Dry? More friction isnt it?
Grooves are designed to cut through water to avoid aquaplaning IMO.
A simple example of a wet vs Dry parking lot, doesnt a wet parking lot make steering the car easier?
I do not own power-steered cars and i can bet it does.
Old 17th December 2011, 02:01   #100
Thanked: 313 Times
Rolling resistance doesn't give better braking performance - sliding friction does. While usually they seem to be linked - that's not the case.
Grooves or not, water ill have to be replaced - that requires energy, hence friction. Water will also reduce the threshold of sliding friction - you can slip more easily - hence aquaplaning. That is also the reason your steering is lighter on a wet road.
vina is offline   Reply With Quote
Old 17th December 2011, 02:20   #101
dhanushs's Avatar
If thats the case...
Try driving in neutral into some stagnant water on the road. You will know. There will be sudden deceleration when the vehicle enters water.
P.S: Please maintain SAFE speeds/practices.
Old 15th December 2012, 16:53   #102
bluevolt's Avatar
City's MID showing 14~15 KMPL since last one week. Winters are here and I can definitely see the increase in mileage yet again.
Old 15th December 2012, 17:28   #103
clevermax's Avatar
Thanked: 403 Times
@clevermax
I am no expert but I feel that wet roads actually may increase the rolling resistance.
I would do a simple test - roll down something cylindrical from a fixed height ramp over a dry wooden surface, and then make the surface wet and try again, and check how far it has rolled before stopping. Obviously you get more distance on dry surface.
Going by your point, highest mileage can be achieved not on dry tarmac but on black ice... But we know mileage sucks on such surfaces.
Not denying that rolling friction is a factor for mileage. Rolling friction will be lesser when tire and tarmac makes contact through air than through a more viscous and denser medium like water. Obviously, more energy is needed (wasted) in order to push water out while tire tries to make contact with tarmac, than air - prove me wrong in this point.
Braking friction is another thing altogether, which is less on water and more on dry surface, which has no direct relation with mileage.
And, lower traction cannot increase mileage.
You just stated what I had to say, in a brief sentence.
clevermax is offline   Reply With Quote
Old 15th December 2012, 22:16   #104
Thanked: 13,345 Times
I feel that the engine sounds are low in winter when compared to the hotter months. Have anyone else felt this phenomena?
Will the denser air have any affect on the sound produced by the engine?
Anurag.
Old 15th December 2012, 22:44   #105
msaudf's Avatar
Thanked: 146 Times
its the cold air intake my friends. its denser so its richer in O2 hence cleaner burning of fuel hence POWERRRR
so happy you and happy engine. And because you get more power you lift off the power faster which in turn results in better fuel mileage.
what do u guys think? could i be right?
msaudf is offline   Reply With Quote
Please suggest good Air Cooler Max Gadgets, Computers & Software 97 25th April 2017 14:28
2015 MotoGP Safety Car - BMW M4 with water injection system for cooler (intake) air syedhafeez The International Automotive Scene 0 17th February 2015 02:52
can you add Glove box cooler in car mrkanitkar Modifications & Accessories 12 22nd July 2010 00:28
Do non-common-rail diesel engines work better with warm air? Samurai Technical Stuff 35 23rd January 2010 09:34
Is car performance without safety systems better - due to less load on ECU? vibhu_f430 Technical Stuff 7 17th March 2008 00:04
