Old 29th December 2010, 11:59   #16
whatcanthisbe's Avatar
Default re: Tata Safari 2.2 stolen this morning (DL3C A Y 4878)
Ust to set a couple of things right. The immobilizer is built in /oem. And it is not in they key it is in the remote as if you lock the car and open it with the key and try to start it it will not startuntil unlocked with the remote. And after speaking to a couple of people stealing a safari with an immobilizer (even if the security code is changed) is childs play, under 10 seconds one can start and drive away with the car
whatcanthisbe is offline   Reply With Quote
Old 29th December 2010, 12:13   #17
That basically beats the whole purpose of putting in such security systems if they are so easily hack-able.
Is this Safari specifc knowledge you got or is it applicable to other Immobilizers as well ?
jigbarai is offline   Reply With Quote
Old 29th December 2010, 12:18   #18
Can't be done in newer maruti's and higher end german cars, applicable for allothers esp tata cars
Old 29th December 2010, 12:19   #19
Neilguy's Avatar
Thanked: 51 Times
How do we get the key code of the immobilizer changed to something other than the default value? Is this something the dealer/company will do or can we do it ourselves?
Neilguy is offline   Reply With Quote
Old 29th December 2010, 12:20   #20
tanwaramit's Avatar
Thanked: 387 Times
sad to hear the loss of your beast. Wondering, if the immobilizer code can be cracked so easily ? factory fitted immobilizers should be tough nut to crack. Wonder when will our car companies start making very active deterrents for car thieves.
tanwaramit is offline   Reply With Quote
Old 29th December 2010, 12:25   #21
KiloAlpha's Avatar
Thanked: 1,597 Times
Could this device have been used?
Thieves jam key-fob lock signals in mystery car thefts ? The Register
Or maybe this will make us sit up and think really hard about vehicle security?
http://www.newscientist.com/article/...obilisers.html
Last edited by KiloAlpha : 29th December 2010 at 12:27. Reason: Added another interesting link
KiloAlpha is offline   Reply With Quote
Old 29th December 2010, 12:43   #22
jkdas's Avatar
Thanked: 1,436 Times
If one knows the code and has a mechanical key, one can unlock the car. The steps is given in the manual.
Old 29th December 2010, 12:48   #23
rajismine's Avatar
Thanked: 252 Times
this is sad as well as shocking man....
Hope you find your vehicle back soon...
rajismine is offline   Reply With Quote
Old 29th December 2010, 12:51   #24
Warwithwheels's Avatar
Thanked: 1,026 Times
Sorry to hear about the incident. Hope you get back your Beast soon.
I always make it a habit to place an old mobile phone (Silent Mode, Vibrator off - under the seat/ below the boot mat etc.,) in my car to help track the car in such untoward incidents.
I started following this practice after reading a news report about how a stolen brand new ANHC was recovered within a couple of hours after the incident because of the mobile fone that was left inside the car.
IMO, This works out to be a very cheap and reliable solution.
Warwithwheels is offline   Reply With Quote
Old 29th December 2010, 12:52   #25
v&v
v&v's Avatar
Thanked: 1,099 Times
Sad new. Hope its fully insured. Does your beast used to park at public parking were the attendant keeps the key? this is a place where keys are mostly duplicated even with immobliser.
v&v is offline   Reply With Quote
Old 29th December 2010, 12:56   #26
Thanked: 245 Times
It also requires a special cable which needs to be used to reprogram it. The code is provided in a sealed cover to the owner just like your ATM pin.
If you have all those yes, you can reprogram it.
Safari does not have a RF ID based integrated key but the immobilizer works along with the ECU to lock/ Unlock.
I would reiterate, report this to TATA CS.
Old 29th December 2010, 13:04   #27
Sabby-069's Avatar
Thanked: 19 Times
Really sad & shocked to hear about your loss Whatcanthisbe... Hope you do find it and in the worst case, hope it was fully insured. Guess car manufacturers start to think of other deterrents to keep these car thieves away.
Sabby-069 is offline   Reply With Quote
Old 29th December 2010, 13:05   #28
Thanked: 458 Times
@Whatcanthisbe: Hope you get your safari back soon. Friends, my i10 also has immobilizer. I have not gone in for any security system. Is it recommended?
Simhi is offline   Reply With Quote
Old 29th December 2010, 13:07   #29
BulZire's Avatar
Thanked: 133 Times
Really sad to hear about your loss. Wish you get back the car soon without any hassle. I hope a guy who breaks the immobilizer and steals a car must be a well trained and experienced car thief. I am sure police will surely have a list of such trained car thieves in their jurisdiction. Keep in track with police, they will get back it soon.
BulZire is offline   Reply With Quote
Old 29th December 2010, 13:10   #30
Thanked: 420 Times
Thats really bad I suspect this is done using cloning of your Key.
Those who think RFID based key is any safer need to think twice it can be cloned much more easier then something which needs physical access.
In this age when Credit cards and SIM cards can be cloned what a poor RFID or so called iCAT can do? Buying RFID scanner is easiest job.
I now think mechanical gear lock / clamp should be there in all cars ( though I don't have that myself)..
amitk26 is offline   Reply With Quote
Engine Immobilizer for Safari 2.2 VTT Lx amitk26 Modifications & Accessories 7 5th December 2016 16:01
Delhi - Goa - Delhi 4878 KMs! shelleve Travelogues 21 11th June 2015 22:17
8 Scorpio mHawks stolen-immobilizer codes cracked!!! ramkya1 Technical Stuff 126 31st March 2012 13:05
urgent!! driver beaten and car stolen at panvel. EDIT: Legal Opinion Needed amit_mechengg Street Experiences 190 25th February 2011 22:46
My car got stolen this morning!! GTO The Indian Car Scene 44 18th October 2004 23:19
