Old 20th December 2012, 11:46   #46
tsk1979's Avatar
Thanked: 15,648 Times
Default Re: Driving on Snow - Whats the Secret?
Originally Posted by manolin View Post
Shimla gets snowfall very rarely, so I must assume that it is the soft kind - as in no continual cold to harden it a bit. But the other areas around shimla, including where I will stay maybe colder. I will pay heed and be carefull. Except I really don't know how to protect the underbody except riding the centre of the ruts and that is not feasible in case of snow ruts because it should just contribute to further slippage.
Do not worry. Unless you plan to go to Sangla, you will not find center hump high enough to hit the underbody.
Even Narkanda area does not have such hardened ruts. Only fresh snowfall causes the high center rut, but its powdery. Snow quickly melts here.
Only if you are going to visit very high places(3000mts ASL) you will face trouble, however, Narkanda is on a hilltop at 2700, and since it does not have a feeder Pass(like manali higher reaches have rohtang), temperatures never dip for long enough levels to create those high center humps with packed ice.
tsk1979 is offline   (2) Thanks Reply With Quote
Old 20th December 2012, 12:09   #47
Thanked: 177 Times
Thanks Tanveer, thats reassuring. Just one question - is Hatu's peak that high up? I have seen photos on bcm touring where there is lots of snow there, but i feel this may be too early in the season to really worry.
manolin is offline   Reply With Quote
Old 20th December 2012, 12:11   #48
tsk1979's Avatar
After 2-3 snowfalls, forget 2WD, even 4WDs cannot reach hatu peak. The road piles up 2-3 feet of snow.
I doubt many can even walk upto Hatu during end December.
tsk1979 is offline   (1) Thanks Reply With Quote
Old 20th December 2012, 12:18   #49
Thanked: 177 Times
hahaha! ok. then it will have to be the snow trek that I have been dying to do.
Old 13th November 2013, 13:20   #50
Sushubh's Avatar
Check out this video from UK's AutoExpress.
It seeks to prove just how important it is to get right kind of rubber and it is really more important than anything else. It also demolishes the argument that 4x4's can get out any kind of situation unless it has right type of rubber.
They get two Ford Kugas (Ford Escapes to Americans), one with front-wheel drive and one with all-wheel drive, and they see which one is better at powering up a snowy slope.The front-drive car doesn't make it very far up the hill with its summer tires — and the all-wheel drive version fails to do any better with the same tires. When equipped with winter tires, the front-driver obliterates the all-wheel drive Kuga that's still stuck on summer tires.
The one that does best of all is the all-wheel drive Kuga with winter tires, which makes it all the way up the ski slope. Not surprising. But the video is excellent proof that the tires make all the difference.So, the next time someone insists on spending more on an all-wheel drive car and they don't live in some perpetually snow-covered place, use this to maybe convince them to spend that cash on the right set of tires instead.
Sushubh is offline   (2) Thanks Reply With Quote
Old 14th November 2013, 10:42   #51
sarathlal's Avatar
Thanked: 2,024 Times
To add on, please avoid using cruise control while driving through snow, or icy conditions.
Variation in road gradient will result in sudden automated accelerations, with can initiate a spin out.
sarathlal is offline   Reply With Quote
Old 23rd December 2015, 10:20   #52
Thanked: 2,253 Times
So, had my first encounter with black ice on my way to Narkanda last weekend, near Fagu. On one of the wider turns, it caught me off guard. The car fishtailed, but thankfully, I was going rather slow and it didn't turn ugly for me. Scary experience though.
Saw many cars which had brushed the mountain side after sliding I presume.
I was cautious to not brake and was mostly using engine braking to slow down.
Do chains really help in such conditions? I mean, the ice wasn't present on the entire route but only in patches. One of the local pickup driver I was chatting with while fueling up, advised to lower the tyre pressure a little for some more grip.
Dry Ice is offline   Reply With Quote
Old 8th December 2016, 01:05   #53
nikhilarni's Avatar
Thanked: 16 Times
Originally Posted by Dr.Abhi View Post
Searched a bit, but didnt find appropriate thread.
We all love driving and that too on different terrains.
So what is the real thing you should know while driving on snow. Is it just the skill you acquire with experience?
Good Thread and thanks for initiating this. I too was seeking some info and advice on the same lines
Originally Posted by lamborghini View Post
Well, I have driven extensively on snow.
Hi lamborghini ,
Thanks for the tips. Having recently moved to the US ( Cleveland ) and travelling most weekends to Pittsburgh. I have been told to expect a heavier snowfall this year and to be careful on the interstates and turnpikes.
Your tips are super helpful. Thanks
Originally Posted by lordofgondor View Post
Don't worry too much, give it a shot and you'll experience (and learn from) the real thing. But don't venture into deep snow.
Hi lordofgondor
I can't wait to experience snow driving myself. The safety tips were really useful. I liked the humour in that line
nikhilarni is offline   Reply With Quote
Old 8th December 2016, 02:47   #54
satan's Avatar
Thanked: 802 Times
Also see http://www.team-bhp.com/forum/travel...er-thar-7.html (Winter trip to Spiti in a Fortuner & Thar) for a winter trip blog
or
for just a snow driving video
satan is offline   Reply With Quote
Old 9th March 2017, 03:32   #55
Thanked: 6,246 Times
Default Picking up some ice on the way to Gatwick
So a few weeks ago I travelled from the Netherlands to Gatwick in the UK.
It was dark, misty and very, very cold. When I arrived at the ferry and switched off the engine I could hear the little e-motor of the aerial struggling to retract the aerial. My first thought was I had a problem with the electrical aerial.
However, the car had picked up quite a bit of ice, driving through the mist. Looked quite spectacular. The ice had also build up on the aerial and it would not retract properly.
Driving on Snow - What's the secret?-15697790_710655132425674_7926102673028668220_n.jpg
Driving on Snow - What's the secret?-15781665_710655125759008_7378950300934667765_n.jpg
Driving on Snow - What's the secret?-15741251_709729619184892_1851032759099500789_n.jpg
Driving on Snow - What's the secret?-15726345_710655179092336_670055305199324582_n.jpg
Driving on Snow - What's the secret?-15727325_710655165759004_2954293165383647348_n.jpg
Very nice, but still very cold, day in the UK:
Driving on Snow - What's the secret?-15844627_712037082287479_6864264278002144169_o.jpg
Jeroen is offline   (7) Thanks Reply With Quote
Whats double clutching & whats the reason to use it _Crazi4Speed_ Technical Stuff 109 25th February 2016 08:49
Review: Glacier PLC 1144 Snow chains and SCC ZT729 Snow cables tsk1979 4x4 Technical 5 6th March 2014 10:45
Driving Grand Vitara on Snow...(pics&vids) AMAN_SACHDEV Travelogues 29 30th October 2008 23:29
Whats the fastest i.e whats the highest average speeds that you have maintained naveendhyani Street Experiences 1 3rd April 2006 18:09
Whats the fastest i.e whats the highest average speeds that you have maintained MKRAFT Street Experiences 1 3rd April 2006 17:25
