Old 4th January 2011, 19:04   #1
Thanked: 45 Times
Default Whether RTV paste can replace gasket completely?
I have old lancer, and i need to flush with ABRO, in the can it is said to remove oil pan after flush in case of old cars, so i need to remove the oil pan after flush, but as i enquired in coimbatore, gasket packing for lancer oil sump is not available.
Shall i use RTV paste or any other sort to replace gasket, in case the old gasket damaged during removal, before removing i need to confirm from Tbhpians, though googling and browsing Tbhp, i came after several replies that it can replaced completely with gasket maker, some say it should be used with gaskets as additional safety, i am confused now.
rajivanoj is offline   Reply With Quote
Old 4th January 2011, 19:24   #2
pranavt's Avatar
Thanked: 274 Times
Default Re: Whether RTV paste can replace gasket completely?
Yes. Remove pan, clean the surface very thoroughly. Apply a moderately think layer. Let it harden for 2-4 hours. Then put the pan on carefully.
Old 4th January 2011, 19:34   #3
Jaggu's Avatar
Thanked: 8,685 Times
Or leave the sump intact and further clean up the internals using 2 rounds of flushing oil. Removing the pan and cleaning alone will not help that much anyways.
Old 4th January 2011, 19:55   #4
Thanked: 45 Times
@pranavt
Thank you for reply
@jaggu
but i have only one can of Abro flush, the direction in can, says, 'remove oil pan and clean is advised, in case of engine with high mileage/excessive wear.
I am adding liqui moly 'CERATEC' with mobil delvac MX after flushing, so i need to make sure the engine is clean to get nano ceramic particles do their work on deformed metal. That is the reason i am flushing.
Old 4th January 2011, 22:55   #5
Thanked: 660 Times
also clean the oil strainer, if possible replace.
aren't you getting the original gasket for the sump. ?
Old 5th January 2011, 00:02   #6
Thanked: 45 Times
@ sir alec
the original or replacement gasket for sump is not available in coimbatore, i have enquired, that is the reason i am thinking of replacing gasket with RTV paste 100%.
Replacing oil stainer would be costly, also i am suspicious about its availability, since it is non fast moving part.
Old 6th January 2011, 00:15   #7
Thanked: 660 Times
use loctite then. Its a reputed manufacturer. i have used it extensively.
Old 6th January 2011, 08:57   #8
gigy's Avatar
Thanked: 41 Times
I have used this rtv for gasket making. about Rs140
Old 6th January 2011, 16:35   #9
Thanked: 45 Times
@ sir alec and gigy
Thank you for your help, i shall try to get loctite, i dont think i will get ABRO in coimbatore. So i will hunt for loctite, if not last chance is Anabond RTV paste.
Old 6th January 2011, 20:13   #10
Thanked: 245 Times
I think use it as a repair filling for gasket. Nothing replces the OEM gaskets durability, otherwise it would have got extinct.
How to test for a failed Engine Head Gasket dadu Technical Stuff 35 28th February 2015 13:55
Volvo S60 instrument console failed. Repair or replace? Volvo to replace under Goodwill! jfxavier Technical Stuff 26 13th January 2015 10:49
1971 Triumph STAG Camshaft cover Gasket tsk1979 Post-War 15 27th November 2008 17:56
