Old 6th January 2011, 11:47   #1
Exclamation Problems with Chevrolet Captiva. GM & Dealer unresponsive
I have some issues which cannot be corrected. I did not check them before buying.
Suspension is hard
gear shift cruder(worse than tata spacio)
unsettled ride quality
But these problems have risen after sometime...
Windshield whitening during rain at night on the outside this is not a misting problem (not able to show it to dealer); need to wipe with a cloth using considerable amount of force to get it clean again. (Dealer polished the glass now filled with scratches)
Steering wobbling; excessive during braking.
Steering pulls to the right on sudden acceleration.
Dashboard and panel noise during acceleration.
Poor braking quality braking is not gradual; there is no response and suddenly I get heavy braking.
What am I supposed to do...
Will be thankful for any sugestion from your end.
naveenangels is offline   Reply With Quote
Old 6th January 2011, 15:12   #2
jeeva's Avatar
Thanked: 559 Times
Default Re: Have isssues with my year old captiva - no response from GM or dealer
Get the car serviced at a competent independent garage. How many kms has the car done? Guess the clutch is due for a change. Check the suspension bushes, brake pads and when you get the wheel alignment done, do make it a point to balance and have them rotated.
jeeva is offline   (1) Thanks Reply With Quote
Old 6th January 2011, 18:38   #3
Thanked: 103,670 Times
Default Re: Problems with Chevrolet Captiva. GM & Dealer unresponsive
Naveen,
Firstly, how many kms has your SUV run?
Second, drive a well-maintained Captiva to compare the gear shift, ride quality & suspension to your SUV.
Either your wheels need balancing & alignment, or your brake discs / pads are uneven.
That's the torque steer
Again, compare to another Captiva and gauge if its a problem with your car, or that's how you find all Captivas.
Totally 'CAPTIVA'ted - My Chevrolet Captiva! anantu2001 Test-Drives & Initial Ownership Reports 86 18th October 2017 17:24
Phoenix Volkswagen, Calicut - Terrible experience and unresponsive customer service nidhinsarath Indian Car Dealerships 2 6th July 2016 21:32
Chevrolet Captiva - Technical Specifications & Feature List Stratos Technical Stuff 2 24th June 2011 15:17
3 week old Mahindra Xylo - Key broke in the ignition. Dealer is unresponsive! wanderluster Technical Stuff 19 5th May 2010 17:29
How to upgrade my Captiva LT to Captiva Automatic Tx prabhpreet Modifications & Accessories 8 20th March 2009 17:47
