Old 27th December 2005, 19:09   #16
ananthkamath's Avatar
Thanked: 63 Times
Good luck finding 200 proof. Even that will pull moisture if your not careful or you leave it in your tank for a long while. You need to add 1-2% propylene oxide if you want them to be kept in solution for a long time.
ananthkamath is offline   Reply With Quote
Old 27th December 2005, 23:59   #17
ghostrider4385's Avatar
Thanked: 7 Times
im just shooting darts here, but does'nt using a higher octane (more that 87)for the 800 affect it's engine in anyway keeping in mind it has a very low compression ratio in comparision to other cars?
ghostrider4385 is offline   Reply With Quote
Water/alcohol injection Eklavya Technical Stuff 14 11th November 2009 21:09
Goa- The land of beaches, churches, adventure, alcohol, food and much more.. Tune in! mclaren1885 Travelogues 73 24th October 2008 16:31
Brazil fights oil price with alcohol... Haque Shifting gears 0 10th October 2005 08:53
