Old 10th January 2011, 22:28   #1
Default Honda Accord 2001 - Electric Seat not functioning
Hi guys,
Have an accord for which the seat adjustment for forward and backward is not working, ASC says 40k for replacing the whole set. Took it to local mechanic and seems one motor is not working. To service it, its at end and no means to open it up unless I take it to some specialist.
Did anyone had sucess it getting it rectified and could I have some details. Also I am from Bangalore so would be great if you can share sucess stories that I can get it rectified.
kiran1103 is offline   Reply With Quote
Old 10th January 2011, 23:55   #2
Thanked: 660 Times
Default Re: Honda Accord 2001 - Electric Seat not functioning
you need an expert auto electrician.
The servo rarely fails, I doubt motor is the suspect. It can be a case of wiring fault.
Old 11th January 2011, 00:08   #3
IQBAL VEERJI's Avatar
Thanked: 291 Times
Also it could be only drive cable my electrician did it in less then 10 seconds and did not even charge me.
IQBAL VEERJI is offline   Reply With Quote
Old 11th January 2011, 21:19   #4
He did check the wiring. The motor just cranks or makes a click sound but nothing happens. It is supposed to rotate the two lenghty screw type which is connected to seat railing. Will be taking it over the weekend.
2001 Honda Accord 2.3 VTi Review - Now Sold @ 75Kkm lamborghini Long-Term Ownership Reviews 26 3rd June 2010 19:11
Honda Accord VTi vs Honda Accord V6 Dinesh99 Technical Stuff 48 9th March 2010 02:08
September 2001 Honda Accord 2.3 VTi for sale in Mumbai lamborghini Shifting gears 2 15th April 2009 03:07
Wanted - Honda Accord 2001 or 2002 model deepug Shifting gears 0 21st September 2007 11:45
Zen's ac not functioning...! Tarun Technical Stuff 4 14th March 2005 13:10
