Old 11th January 2011, 16:22   #1
Thanked: 16 Times
Default Skoda Octavia: Automatic Transmission Overhaul
I just finished overhauling the auto gear box...whew ! four months of struggle and research and finally. These tranny's are a problem to fix in India. Realised that a rat had got to the wiring between the ECM and the Valve body.
  • Replaced valve body solenoids, cable strap
  • Replace wiring from ECM to Transmission
  • Overhauled the Gear box with a fresh kit
What an escapade. Anybody needs help on the Auto Tranny's do get in touch
Note from Moderator: Post Formatted to make it easier to understand. Please proof check your post before hitting the submit button. Please use full and proper English when posting on Team-BHP. Thanks
Last edited by .anshuman : 11th January 2011 at 18:33. Reason: See note in the post.
getanilkhanna is offline   Reply With Quote
Old 11th January 2011, 17:09   #2
Mpower's Avatar
Thanked: 1,687 Times
Default re: Skoda Octavia: Automatic Transmission Overhaul
HOw many kms on your vehicle? Was the overhaul done at dealer?
Old 11th January 2011, 17:25   #3
Some background would help here.
Why was the overhaul necessary if it was just rat wire damage ?
Did you DIY or the service center folks help in fixing the issue ?
jigbarai is offline   Reply With Quote
Old 11th January 2011, 18:36   #4
.anshuman's Avatar
Thanked: 9,159 Times
Default Re: Skoda Octavia: Automatic Transmission Overhaul
getanilkhanna, i have a few questions for you.
  • Why was the whole gearbox overhauled if it just damage to the wiring by the rat?
  • Where did you get the Job done? Also if it was someplace else than the ASC, Where did you source the parts from?
  • How much did this cost?
  • How much has your car run till date? Are you the first owner of the car?
Old 11th January 2011, 18:41   #5
Thanked: 16 Times
The rat got the wiring ....so the ECM was unable to recieve the right info from the solenoids on the valve body.
The auto shifter used to jump to neutral rather than shifting to 2nd
Thought that the ATF level was low (Since there is no way to check the level)
Added Voltronic ATF 9K about 500 ml
Then the shifter simply refused to work. It was constantly stuck in the 1st gear
That burned the plates
Well I recommend that every New Tranny should go for a drain at 30,000 kms
Later it will last for 60,000 Km...but the first should be at 30,000
I did not change till 60,000 since i bought it as a second hand
The valve body was choked with sludge
NO The service centre refuses to dismantle the Auto box and suggests complete change @ Rs 5,25,000
Had a professional job done outside
getanilkhanna is offline   (1) Thanks Reply With Quote
Old 11th January 2011, 19:19   #6
Thanked: 1,172 Times
Which plates are these?
This is a torque converter based AT or DSG?
And who is this professional who did the job?
anandpadhye is offline   Reply With Quote
Old 11th January 2011, 19:25   #7
.anshuman's Avatar
^^ The Octavia AT came with a Torque Convertor Auto.
Old 12th January 2011, 10:38   #8
Thanked: 16 Times
The AT gearbox with the Torque converter comes with multiple clutch plates
Constant usage in the gear 1 (Since the auto shifter was not working) caused the plate to burn out, however the damage was not immense as I noticed that the gears were not changing and the RPM increased simultaneously.
That is when I contacted this guy in Zamrudpur Delhi to help me out
He did take time , however he carried out a terrific job.
Old 12th January 2011, 20:45   #9
Thanked: 660 Times
Did you documented the whole episode of transmission overhaul. Images would have helped lot of people.
Old 19th October 2017, 20:36   #10
Thanked: 37 Times
I happen to come across this product in youtube by chance and found very good reviews about them in US websites , and also its available in Amazon India.
It gurantees to solve hard shifting , slippage and its a thick non- solvent solution which gives immediate results and does not cause problem to transmission parts.
Product name. - Lucas Transmission Fix
Did any one try this out?
Rama Naveen is offline   Reply With Quote
Automatic Transmission wolfgangsiva Technical Stuff 7 2nd April 2018 13:02
Automatic Transmission - Gearbox oil change vinodbijlani Technical Stuff 14 25th May 2016 15:20
Mercedes Benz 300D (W123 series): Manual Transmission to Automatic Transmission. wartikars Post-War 5 3rd January 2014 12:39
Skoda Octavia at 175k kms- Suspension, Brakes, Axles etc overhaul query metanoia75 Technical Stuff 1 26th November 2011 12:54
Wheelspin in an Automatic Transmission (A/T) Dippy Technical Stuff 24 6th December 2010 22:19
