Old 4th July 2010, 02:15   #31
ph03n!x's Avatar
Thanked: 120 Times
Originally Posted by ritedhawan View Post
he second reason--that got me curious-- that he gave me was, not to run these cars on reserve fuel, always have enough fuel such that the fuel meter needle is above reserve.
I have heard this too - and follow it as much as I can by tanking up at 1/4th itself. The logic is that the fuel pump is a highly stressed component, what with having to pump fuel into the common rail which itself is under several bars of pressure. So enough fuel in the tank helps. Also, having more fuel implies less impurities per volume, and less moisture presence - both can be killers of the CRDi.
ph03n!x is offline   Reply With Quote
Old 4th July 2010, 23:07   #32
Thanked: 103,374 Times
If you want your diesel engine to last long, work the torque and upshift early. No point in high revving common-rail diesels; their redline starts way too early (4,000 rpms or lower, compared to 6,000 for most petrols). All the torque is lower down the rpm range anyways.
Diesel Owners: Please share maintenance Experiences / Advice Eddy Technical Stuff 2 30th November 2007 10:49
Precautions / Maintenance for Diesel Engines with Turbo adarsh76 Technical Stuff 18 14th March 2007 15:17
Diesel car maintenance help required!!! Steeroid SUVs, MUVs & 4x4s 24 5th March 2007 09:28
