Old 14th January 2011, 16:46   #1
smashnerd's Avatar
Thanked: 19 Times
Question Truck Diesels vs. Car Diesels
Why are truck diesel engines having a high displacement and sticking to 6 or 8 cylinders in a straight line? Diesels in cars have cylinders in V orientation and some even make more power from a lesser displacement than say the Volvo 9400s.
Why is this so? Is it simply for torque?
smashnerd is offline   Reply With Quote
Old 14th January 2011, 17:31   #2
CPH
Thanked: 34 Times
Default Re: Truck Diesels vs. Car Diesels
In a truck space is not at a premium. Engines can be designed totally different.
Also you have to appreciate that trucks can be as heavy as 30 luxury cars.
An inline engine is easier to balance than a V configuration. With the extreme mass of big Diesels this has got a heavy impact.
In some areas commercial Diesel run between 1,20,000 to 1,80,000km a year carrying a lot of weight. These engines need to last at leas 10 lakh km.
This can only be done with lowe revving engines that have extreme torque outputs. Additionally the low rpm is good for fuel economy.
In passenger cars it is a bit of a different story. The engines have to have a wide torque range, good torque and have to be efficient without losing comfort for the driver. This ask for a different approach.
CPH is offline   Reply With Quote
Old 14th January 2011, 17:49   #3
smashnerd's Avatar
Thanked: 19 Times
There are 3 liter engines in cars making ~500 Nm of torque at 1500 rpm or so.
What kind of figures are we looking for an average truck diesel?
Old 15th January 2011, 05:02   #4
dhanushs's Avatar
Thanked: 4,507 Times
Its not only figures on paper that do that job. Where, and how it is delivered across the rev range determines drivability/practicality of the engine.
Old 15th January 2011, 08:57   #5
smashnerd's Avatar
Thanked: 19 Times
Could you elaborate a bit more on the "how it is delivered in the rev range"?
Old 15th January 2011, 11:11   #6
sgiitk's Avatar
Thanked: 3,884 Times
Truck engines are low revving (very rarely rev. to 3500rpm). PD is common (noise is Ok), and valve lifters/cams are mostly rotary. All in the interest of a long life and low consumption.
Old 15th January 2011, 13:26   #7
CPH
Thanked: 34 Times
Engines for smaller commercial vehicles start at about 70Nm. Bigger trucks vary from about 1200 to over 4000Nm.
The torque requirement depends on a number of conditions, where terrain is one of them. If you have a 44 ton truck and have to cover rugularly level differences of many hundred meters much more torque will be needed or you never will get anywhere. At the same time you need to maintain fuel economy.
a modern 5+ liter truck engine will not even rev beyond 2,000rpm. and may tick over as low as 200rpm. These engines need shifting for optimal fuel econmy at about 1200rpm the latest and usually cruise around 900rpm.
The turbo comes in soon above tickover. It is fairly easy with modern ECU control and VGT turbos to a low lag performance, which is aided by the narrow RPM range of big engines. Additionally todays gearbox technology helps where the semi automatic gearboxes select the best rpm for the individual application. These gearboxes start with 12 gears and might have more than three times as many gears.
Old 15th January 2011, 16:41   #8
smashnerd's Avatar
Thanked: 19 Times
What's PD? And what do you mean valve lifters/cams are mostly rotary?
Mercurio Pallia to launch "truck-on-truck" product, and target car transportation biz GTO Commercial Vehicles 3 23rd November 2011 23:52
A day with the monster truck, an awesome Shockwave truck and a few fighter planes ... jango The International Automotive Scene 9 16th October 2008 14:57
Any info on modifying diesels mmmjgm Modifications & Accessories 2 20th December 2004 15:44
Small Diesels. Which one? anshu12420 Hatchbacks 21 20th August 2004 17:51
Maruti-Suzuki now dedicated to Diesels!! GTO The Indian Car Scene 3 10th April 2004 15:14
