Closed Thread
Old 16th January 2011, 00:52   #1
Default Overheating Engine
Mod Note : Please continue the discussion in our Engine Overheating Article (What to do if your Engine Overheats on the road). Thanks
My palio 1.2 has done about 57K kms. In my last service Concorde replaced the fan saying some bolts have come out. From that day, the engine temperature which used to show 1/4 started to move frequently to 1/2 mark. Nowadays, the temperature gauge will be showing 1/4 when the car is in motion. However if the car is stationary for more than 1-2 minutes, the temperature gauge shoots up to 1/2 mark. Also the bonnet feels extremely hot after a journey. Another issue that was noticed was that the fan keeps running almost throughout the journey.
Also i have noticed considerable dip in mileage of the car.
The second niggle is that some kind of fan turns in the engine bay every time i turn the blower / AC of the car on. This fan would be on for the entire length of the time the AC/ blower is on.
Please do let me know what may be the issues i need to look at.
viana is offline
Old 16th January 2011, 01:11   #2
esteem_lover's Avatar
Thanked: 445 Times
Default Re: Overheating Engine
I think the palio has a single fan which operates in 2 speeds. So when you switch on the AC, the fan WILL start and when the engine gets hot, the fan will go into the second higher speed unlike some other cars which have different 2 fans for this. Make sure they have installed the fan in proper alignment to the radiator. Take it back to the garage and have them check this out, do not drive like this for long.
esteem_lover is offline
Closed Thread
Ikon Engine Overheating and Damage zuch Technical Stuff 69 30th May 2014 19:25
Indica V2 DLS - Engine overheating/AC issues ajaysurfs Technical Stuff 8 18th June 2012 20:54
Engine Overheating... Siena 1.6 urdudesamy Technical Stuff 17 13th December 2008 10:34
Esteem - engine overheating - TECH2 gives normal reading ad75 Technical Stuff 22 10th March 2008 12:01
Engine Overheating: Urgent Help Needed! Su-47 Technical Stuff 14 3rd March 2007 10:38
