Old 29th November 2015, 22:36   #31
Chewbacca's Avatar
Thanked: 121 Times
Default Re: Lancer SLX 2002 Model Electrical Problem
Check the right upper side of the dashboard, there should be a separate switch for the fog lamp. If you have that then the wires/relay/fuse/cabling should also be present and you simply need to connect the lamps. Mine is SLX model that came with original fog lamps which draw a lot of current.
Chewbacca is offline   Reply With Quote
Scorpio SLX All Black (New Model), 65K kms 3 yrs Ownership review... SamtheLeo Long-Term Ownership Reviews 19 4th May 2012 21:15
Lancer sfx, slx and glx -- Body differences (If any?) raajks Technical Stuff 58 26th August 2010 09:43
Strange Heating Problem in 2002 model santro Pls..... help manne Technical Stuff 9 17th May 2009 03:53
For Sale : Mitsubishi Lancer SLX D n_aditya Shifting gears 1 4th May 2006 16:51
