Thread Tools
Old 2nd January 2006, 14:42   #1 (permalink)
Dragonov's Avatar
Question Need some advice.
Hi guys, wish you all a very happy and prosperous new year. I have a Ikon 1.3 Rocam which has done about 14K kms, the only additional add-on I have done so far is that I have a K&N OE replacement filter instead of the stock filter and alloy wheels. But the problem I have noticed recently is that whenever I up-shift gears from 2nd-3rd or 3rd-4th or even 4th-5th the engine rpm rises by about 100rpm and then after the gear change it normalizes. Could it be a problem due to the K&N filter or due to something else ?
Also as I actually dont want to alter my original engine specifications right now.. So if some body could advise me on what kind of performance upgrades in terms of acceleration and top-speed should I go in for ? And where in the NCR can I get this kind of help?
Thanks..
" Quality is never an accident, it is always result of intelligent efforts ".
Dragonov is offline   Reply With Quote
Old 2nd January 2006, 15:27   #2 (permalink)
v1p3r's Avatar
Do you have a tacho where you are noticing this, or is it just a gut feeling? Also, what rpm are you shifting up at?
__________________
Singh is king?! He's a bloody baadshah!
Old 2nd January 2006, 15:51   #3 (permalink)
Dragonov's Avatar
Yeah the Ikon comes with a factory fitted tacho from where I notice the change in RPM and I generally up-shift between 1000-2000rpm depending on the speed and the gear I am using..
Old 2nd January 2006, 15:59   #4 (permalink)
Originally Posted by Dragonov
whenever I up-shift gears from 2nd-3rd or 3rd-4th or even 4th-5th the engine rpm rises by about 100rpm and then after the gear change it normalizes. ".
hey, how are you able to notice a rise in rpm by 100, is it not a marginal rise to be noticed unless you have some instrument to measure or have a digital tachometer. could it be parallax error???
tifosikrishna is online now   Reply With Quote
Old 2nd January 2006, 16:21   #5 (permalink)
Dragonov's Avatar
Hi tifosikrishna.. I can feel the rise in rpm while pressing the clutch for the gear change and I judge the differnce to a count of roughly a 100rpm by what I see in tacho meter provided in dashboard.. also I could not understand what you meant by a parallax error ?
Old 2nd January 2006, 21:15   #6 (permalink)
.anshuman's Avatar
if you need performance why did you go in for a 1.3 ikon,1.6 is a superb performer and if didnt want to shell out more money you could have bought a accent 1.5gle for similar amount of money.
__________________
Anshuman Bishnoi
Hyundai Elantra CRDi 2.0
Mahindra Scorpio VLX 2.2
Suzuki Swift VDi ABS
.anshuman is online now   Reply With Quote
Old 3rd January 2006, 10:34   #7 (permalink)
Dragonov's Avatar
anshuman..its not about what I should have bought and what I have bought..!! I am very much happy with my car and its current performance and I did drive around a Ikon 1.6 for abt 2 years, so this time I wanted a car more fuel efficient and somewhat similar to it but at the same time more agile than the accent 1.5Gle.. If you really can advise me about the RPM problem with my car, please do so..or else there is no point debating on the performance orientations of various models...
Old 3rd January 2006, 21:55   #8 (permalink)
tsxei's Avatar
Some of the Honda engines do this intentionally. They are designed to keep the rpm up momentarily during up-shifts in order burn off excess fuel to reduce emission. Maybe Ford has a similar feature.
__________________
My other Honda is a CBR600RR.
tsxei is offline   Reply With Quote
Old 4th January 2006, 00:00   #9 (permalink)
nitrous's Avatar
Clutch slippage is my guess. But, a slipping clutch will revv around 500-1000rpm before engaging gears.
__________________
hindu.com/mp/2008/08/25/stories/2008082522220200.htm
Thread Tools
Need Advice for new sub akg7091 Ask the Gurus 67 1st October 2007 09:27
Need Advice smnaren Ask the Gurus 5 5th September 2007 11:54
Need Advice scorp 1 Route / Travel Queries 6 28th September 2006 00:46
Please advice and help... raja748 Technical Stuff 4 8th August 2006 16:00
Need Advice akumar Sedans 11 19th July 2004 19:48
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446
