Old 3rd February 2011, 23:54   #1
Thanked: 33 Times
Default Innova [?steering] noise question
hi guys,
A friend has an Innova which he bought recently. It makes a kind of 'whoosh' noise when the engine has just been started and the steering is turned completely to one direction.
is this normal? Something to do with the power steering?
Thanks.
kumar2007 is offline   Reply With Quote
Old 4th February 2011, 00:24   #2
.anshuman's Avatar
Thanked: 9,159 Times
Default Re: Innova [?steering] noise question
Most cars with Hydraulic Power steering make a hissing noise when the wheel held at lock on both sides. The question is how loud is this sound? Compare it to another car of the same make.
Old 4th February 2011, 01:06   #3
Jaggu's Avatar
Thanked: 8,684 Times
^^ +1 some make nice woosh sound, like the iKON which is quite normal. Still a comparison would be good, just to rule out any issues. Then again its a Toyota nothing much can go wrong so soon.
Old 4th February 2011, 03:11   #4
dhanushs's Avatar
Thanked: 4,504 Times
Yes, it is quite normal for an IKON.
I have one question: Is it advisable to hold the steering in full lock (whist that sound heard) for longer durations for any PS car?.
Old 4th February 2011, 18:20   #5
Thanked: 22 Times
Dhanushs, It is not adivsable to hold the steering at full lock for more than 30 secs as the PS pump is at the maximum pressure. Regular full locks for long duration can rupture the pump's seal.
spookey is offline   Reply With Quote
Old 4th February 2011, 18:37   #6
Thanked: 141 Times
+1
It is also advisable to avoid (when possible) the 'TAK' sound of the full lock on either side. With the full lock the seal can lose its life faster.
narayanang76 is offline   Reply With Quote
Old 28th July 2011, 22:16   #7
Thanked: 33 Times
Apparently its the ABS motor undergoing a self test when you start. It also kicks in when you hit the brakes on a slippery patch. As per the instruction manual.
Old 28th July 2011, 22:45   #8
dhanushs's Avatar
You mean the ABS pump motor?. If so, whats it gotta do with steering full lock?.
Old 29th July 2011, 08:02   #9
Thanked: 33 Times
My error. apparently it's not always on full lock, and happens otherwise too. Just that he does a full lock to get out of his parking spot every morning/evening, and thought it was on full lock.
He later noticed it [same noise] when ABS kicked in when braking on sand and read this in the manual too.
Stebel Nautilus Horns - gargling noise? no noise? gd1418 Technical Stuff 31 23rd May 2011 21:59
Elantra rare noise (hissing noise) Please help!! manne Technical Stuff 9 28th June 2010 09:24
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
Power steering noise pankaj09 Technical Stuff 19 25th April 2005 22:42
