Old 10th February 2011, 13:25   #16
muditgrover's Avatar
Thanked: 133 Times
Default Re: What is this? On the Hood? EDIT - Fuel Injectors for Blowers
Thanks a lot for so much of information.
Any chance of using supercharger and turbocharger at the same time?
Which one is powerful? Supercharger? or Turbocharger?
Thanks and Regards
muditgrover is offline   Reply With Quote
Old 10th February 2011, 13:29   #17
absynthguzzler's Avatar
Thanked: 224 Times
Thanks and Regards
There are threads already for this question and have been linked in previous posts .
Oh yes, size does matter! Hotrods have never caught on (and probably never will) in a country obsessed with "kitna deti hai?" , and these modifications are meant to take power output into a different league altogether.
however, this link proves otherwise , in particular to the roots type blower models as seen in the picture. a quote from the site says
"Roots superchargers are usually large and sit on top of the engine. They are popular in muscle cars and hot rods because they stick out of the hood of the car. However, they are the least efficient supercharger for two reasons: They add more weight to the vehicle and they move air in discrete bursts instead of in a smooth and continuous flow" .
The link is a good read muditgrover, should answer your doubts as well. Read up on "twin-chargers" for your query
absynthguzzler is offline   Reply With Quote
Old 10th February 2011, 13:44   #18
AutoNoob's Avatar
Thanked: 278 Times
Any chance of using supercharger and turbocharger at the same time? Which one is powerful? Supercharger? or Turbocharger?
Theoretically yes. Both can be used together either in series or parallel. Practically, it will be difficult to integrate the two. For this intermediate, NRVs and intercoolers will be needed. It is always better to have multiple stages in the same unit.
Turbocharger takes energy from the waste exhaust gases, so improves overall efficiency. On the downside, due to lack of positive drive, large compression ratios can't be achieved. Therefore this is not as powerful as a supercharger which has a belt or chain drive. Supercharger reduces the overall efficiency but if we are opting to supercharge our engines do we really care about efficiency or milage
AutoNoob is offline   Reply With Quote
Old 10th February 2011, 13:46   #19
AlphaKilo's Avatar
Thanked: 417 Times
Excuse me to reignite this thread! I first of all thank all those who have corrected my definition for a super and a turbo charger.
1. I forgot to write the word "compress" while explaining turbo chargers.
2. I did not want to confuse Little grover by giving him too much information at once and wanted him to do a search in TBHP by himself once given the lead on super and turbochargers.
anyways, all that is solved and explained now, let me close my statement here.
Again, thank you guys for correcting my mistakes. I shall be watchful anymore!
AlphaKilo is online now   Reply With Quote
Old 10th February 2011, 18:35   #20
pranavt's Avatar
Thanked: 274 Times
Supercharging and turbocharging at the same time is quite possible and has been done for decades now.
That makes no sense as you can make equal amounts of power with less boost if you are running higher compression. The only problem, if you can call it that, is the fact that tuning timing becomes a bit more critical. Comparing superchargers to turbochargers is like comparing apples and oranges.
Hot air from blowers Mafia Technical Stuff 7 7th April 2010 17:21
Fuel Injectors Cleaning - DIY vigsom DIY - Do it yourself 4 25th December 2009 11:35
How to check if Fuel Injectors are alright? extreme_torque Technical Stuff 4 28th July 2006 10:00
Fuel Injectors Added to an Indian Bike? srikantans04 Motorbikes 3 15th June 2006 19:01
