Old 11th February 2011, 08:32   #1
download2live's Avatar
Thanked: 387 Times
Exclamation A cut wire in my Punto. Safe to drive?
If mods feel appropriate then they can move it to different section. After my chennai trip I saw a tube/wire dangling over the rear right tyre. Initially I though that I would be some tube/wire which might have got loose and hence kept driving. But after reaching home I had a close look at it. And it turned out that it was a tube which had got cut into two. Find the pics attached.
This is the tube which is hanging.
See where it is coming from.
Me holding the two ends.
One more view. See where it is coming from.
Another picture.
Another picture.
Another picture.
Any ideas what this can be? Its not rear brake wiring. I checked. The reversing lights are also working.
Is it something which I can drive around with for some time? Or needs immediate attention?
I had got the rear end almost totally taken apart by the Concorde Diary circle when they were trying to sort out the rear suspension noise. Is it possible that they were not able to put it back together properly?
download2live is offline   Reply With Quote
Old 11th February 2011, 09:45   #2
Thanked: 197 Times
Default Re: A cut wire in my Punto. Safe to drive?
Looks like the breather pipe of the fuel tank. However I would get it checked asap.
Ravindra M is offline   Reply With Quote
Old 11th February 2011, 11:35   #3
Thanked: 387 Times
*EDIT*
Took the car to the Concorde Dairy Circle. Turns out that this is a kind of drain pipe. One end of it (the one with a clean round cut) is fixed near the fuel cap. The other end (the jagged slant cut) goes down near the suspension. Somehow this pipe on both the ends came out.
The use of this pipe seems to "Collect the spilled fuel while filling time and drain it to ground below safely."
I will post more pics once I reach the home.
Old 11th February 2011, 11:59   #4
HammerHead's Avatar
Thanked: 210 Times
Originally Posted by download2live View Post
*EDIT*
Not sure if yours is GP, but I had similar pipe like thing hanging out at the exact same location in my GP. B.U.B fixed it during 1st service.
HammerHead is offline   Reply With Quote
Old 11th February 2011, 12:05   #5
WasavaTyres's Avatar
Thanked: 239 Times
Fuel drain pipe for sure. Hope they replaced it for you.
WasavaTyres is offline   Reply With Quote
Old 11th February 2011, 12:25   #6
Thanked: 387 Times
Mine is a GP emotion.
They did not replace it. Just plugged it back in the rubber casing around the fuel inlet cap.
Tata Motors on an austerity drive. Production cut too ghodlur The Indian Car Scene 67 3rd April 2013 14:07
SX4 : Throttle Body Adjustment on drive by wire iTNerd Technical Stuff 22 13th July 2012 09:33
Grande Punto Facelift: From baby Maserati to Punto Evo EDIT: Punto 'My Life' on pg.7 sushanthr77 The International Automotive Scene 167 25th November 2011 12:02
Drive by Wire Technology ajaysurfs Technical Stuff 51 18th May 2011 11:29
NHC drive by wire? sreenidhibr Technical Stuff 13 8th February 2009 22:54
