Old 11th February 2011, 23:12   #1
vsk2009's Avatar
Thanked: 23 Times
Default Nanotechnology in future cars
Following links may be interesting for those who are interested in future technological innovations in automobiles. (I think a new section or a dedicated thread for technological innovations for automobiles may be ideal for similar posts)
BMW Goes Nano
Tata Nano Car Blog Archive New Projects Using Nanotechnology in BMW
Any guess about the smallest car that man has ever made? see below
Tata Nano Car Blog Archive real miniature - nano car
vsk2009 is offline   Reply With Quote
Old 8th March 2011, 16:15   #2
vsk2009's Avatar
Thanked: 23 Times
Default Re: Nanotechnology in future cars:Friction reduction in Engines
March issue of science daily has reported a new Nano polymer particles that, when added to automobile engine oils can reduce friction by 55% than the current friction additives. The research has done by Prof. Guojun Liu, Queens University. An industrial utilization of the technology can increase the engine efficiency considerably.
Nanotechnology used to prolong machine and engine life
Old 9th March 2011, 13:23   #3
mukundmenon's Avatar
Thanked: 27 Times
check out Pureshield Range of Nanotechnology Products for their array of nanotech products for use in cars.The windshied coating is real good.saw a demo on a Beat with the sealent applied on it.The murky water just ran off the glass like little beads.The dealer quoted a price around 1K for it, can be applied ourselves, said it will last a year .It seems like a good VFM product though at first i thought they used the words 'nanotechnology' to just lure people.It was amazing to watch the demo vids on their site as well!
mukundmenon is offline   Reply With Quote
Old 9th March 2011, 20:44   #4
dot
dot's Avatar
Thanked: 714 Times
@vsk2009, never imagined that at TBHP will discuss science and technology with someone. Are you in research too? Actually I wanted to work with this guy (Liu) several years back, but something else had materialized that time.
As you know, several so called nano technology is actually used in our everyday cars.
For example, the toughened bumpers which has dispersed rubber that can be made from olefinic block copolymers. These polymers gets dispersed as nano/micro domains ina PP matrix. Eventually they help in absorbing energy when a impact occurs.
Then, almost all lubricants carry dispersants which can also classified as nano tech.
The application I really admire is the alternating multilayer polyester sunfilm that uses a photonic band gap concept to reflect off IR.
Self healing paints are actually possible, but way too expensive to impliment. So while at universities they are a good fashion to talk about, the market is not ready yet.
Finally "plastic" body parts like fenders or composite roof tops have nano fillers or dispersed nano domains of a second or third component. All these in current production for many vehicles.
And then there are posers, like a highly hydrophobic coating which when applied forms a "water repellent" surface coating.
Do post if you know any other applications. Always interested to learn!
dot is offline   Reply With Quote
Old 13th March 2011, 14:55   #5
vsk2009's Avatar
Thanked: 23 Times
Looks interesting. But nothing is specified about the UV protection and VLT
The application I really admire is the alternating multilayer polyester sun-film that uses a photonic band gap concept to reflect off IR.
Thanks for new informations. As you said correctly, there are already many nano technology used in many cars. The Tata Nano has used it.(Sorry that I couldn't give the correct information.This I got from the slide of a seminar talk on Nano science) Even many companies may have the new technologies with them but at the current scenario the mass production may not be profitable. Here I found a interesting video of the application of Graphene(some of the applications can make the dash board more smarter). I got this link from my friend who is working on graphene.
Old 20th March 2011, 22:25   #6
dot
dot's Avatar
Thanked: 714 Times
@vsk2009, awesome video. I don't know too much about graphene other than its chemical structure and superior percolation and electrical properties in a blend. Will try to find out more.
Old 20th March 2011, 23:02   #7
ajman28's Avatar
Thanked: 22 Times
Can you please elaborate a little more on these applications as to what exactly they are?
ajman28 is offline   Reply With Quote
Old 27th March 2011, 01:05   #8
dot
dot's Avatar
Thanked: 714 Times
@ajman28, I will try to explain in simple terms.
On self healing paints.
Powder coated paint is actually a pigmented resin deposited on base coat of a metal/plastic part. People have devised nano carriers or nano spheres that can carry some more resin or catalyst. These "free" resin and catalyst sits inside the spheres lying dormant inside the coat. Once a scratch occurs, the surface of the scratch can release the dormant resin or catalyst which react and fill up the "gap". Usually a thermal stimulus is needed to complete the chemical reaction. This technology is one popular method that can be applied, but very expensive. Several articles are available on the net around this topic.
On multilayered polyester sunfilms.
This technology is not really nano, but can be included. Two polyester resins are coextruded through a die that creates an alternating multilayered film. The multilayered films bends back light of a certain frequencies. The refractive index and thickness of each layer determines which light frequency will be blocked or reflected back. Technically this is an example of a one dimensional photonic band gap. The materials can be tailored to reflect back visible or UV radiation. In that case the thickness of each alternating layer will be nearing the "nano" range. There are 2D and 3D photonic band gap materials, but their applications are in optics not automotive. Again googling the net gives lot of information around this topic.
Hope it helps!
Old 1st November 2011, 19:50   #9
ramanan.skr's Avatar
Thanked: 17 Times
Did you get this product? Is it available in all auto shops?
ramanan.skr is offline   Reply With Quote
Old 5th November 2011, 22:32   #10
Thanked: 27 Times
Nope.I don't think it's available at accessory shops. Their website may have the info on dealers.
Old 27th March 2012, 18:36   #11
Thanked: 29 Times
Wanted to check if anyone has tried the Car Glass Sealant from Pureshield Impex based out of Chennai (Pureshield Range of Nanotechnology Products)
I was catching up my reading and one of the periodicals had the advt. I sms'd them and got a response back from one of their people.
They do not have a dealer in Blr but are willing to ship it. Their MRP for front windshield is Rs 899/- Evidently these are tissues that need to be rubbed with the vehicle parked under some shade and then needs to be kept for 4-6 hours before taking the vehicle out.
Before ordering wanted to know if there were any users of this?
indianrunner is offline   Reply With Quote
Old 28th March 2012, 10:19   #12
brraj's Avatar
Thanked: 354 Times
Audi A9 – Hybrid Car Able to Repair Itself Using Nanotech Material
source
http://auto.infoniac.com/2010/05/aud...tech-material/
brraj is offline   Reply With Quote
Old 16th April 2012, 19:29   #13
Thanked: 29 Times
I got the 'nano' coating done on the front windshield through Windshield Experts. This is a third party product that is marketed by WE.
The person came home and cleaned the windshield thoroughly and then applied 2 coats of some other liquid. Did a good job.
This application makes the windscreen cleaning easier in case of bird droppings, mosquito hits while traveling on the highway, driving in the rain etc. Post the application, only water needs to be used to clean the windshield for its effective period which is claimed to be about an year (!)
The last couple of days there is certainly less dust settling on the windshield. I should be going to Pune tonight so easily does the windscreen clean with the mosquito hits. I dont expect rain on the way so will not be able to test that out!!
Cost was about Rs 1000/- for the front windscreen.
Old 30th September 2013, 21:32   #14
Warwithwheels's Avatar
Thanked: 1,026 Times
Found this video on Youtube. Anybody tried this product recently? Any well established brands selling the product?
Warwithwheels is offline   Reply With Quote
Cars: Where does the future lie? Why so many lies in the present? FlatOut Technical Stuff 70 16th May 2017 08:47
Clarkson upsets Nissan by saying electric cars are "not the future" noopster The International Automotive Scene 55 14th December 2011 14:31
The future of Cars - Automatrix RacingHart Technical Stuff 4 17th October 2011 23:48
Cars of future - let your imagination begin!! sathya_nars The Indian Car Scene 17 30th August 2007 19:34
