Old 8th March 2011, 08:30   #16
geeash's Avatar
Thanked: 132 Times
Default Re: ECO:Drive is working in Fiat Linea !!!
@h14
yeah probably your car already had a 5.5 version. happy eco:driving!!
geeash is offline   Reply With Quote
Old 8th March 2011, 11:25   #17
Thanked: 18 Times
Originally Posted by geeash View Post
@h14
@geeash,
What is fleet id? When I tried to create a profile, its asking this id and is a mandatory too...
also, which country I should select for my Linea petrol?
Kumar
ndinesh is offline   Reply With Quote
Old 9th March 2011, 10:53   #18
geeash's Avatar
Thanked: 132 Times
fleet id is not for us . you can ignore it.
it is better if you choose turkey for linea petrol as it will then give your consumptions and distance in km and litre. if you choose uk it will be in miles and gallons
Old 10th March 2011, 16:02   #19
geeash's Avatar
Thanked: 132 Times
a new version of ecodrive available for update 8.9.9.2424
automatically updates on launching ecodrive
ECO:Drive is working in Fiat Linea !!!-untitled.jpg
Old 20th August 2011, 17:08   #20
Hi, I had been using Eco Drive since April 2011 in my Linea Emotion Pk ,but then I was out for 2months, this june and july. And now Ecodrive is working but my data doesnt go into the USB. My car screams "LowMemory" but somehow the data is just not being copied to the USB drive ..
I already tried reinserting the USB drive. Resetting the USB. etc ..
but still no luck.. the local Fiat Dealership guys don't even know what EcoDrive is..
Any help.
Jaladhi
jaladhi is offline   Reply With Quote
Old 14th October 2011, 15:27   #21
A happy news to fiat owners here. The ecodrive software which is a valuable addition for blue and me software (in emotion pack linea) has been updated for indian lineas. It is working fine in my car.
I have heard in other forums that it doesnt still work in puntos but works fine in all lineas.
It gives great insights about what is your ecoindex and analyses your driving and does recomendations to improve your driving skills for better fuel efficiency and greener environment
just go to the fiat ecodrive uk site and download thye app and install in your pc and prepare your usb and plug in your blue and me thats all for each trip it will record your journey data and when you plug back the usb stick in to your comp it gives you a ecoindex and will analyse your driving parameters
so guys just install and have fun. if you have any doubts just post it in this thread .
Hi
I have been using Eco Drive for some time with my 1.3 MJD. Two key problems:
1. Only 1.6 MJD Option available in UK Profile.
2. Only a 6 gear variant available and selected by default.
Both factors together mean the the readings are totally useless. I am stuck at around Eco Index of 57 and I keep getting a message that I change gears too often. Then there is this little tutorial that tells me what RPM to change gear at. It seems to suggest I should change to gear 2 at 2000 RPM and I am doing it at around 1000 RPM.
I have been returning around 13 kmpl consistently in Mumbai City. And I have a relatively free run on JVLR and because of BPO timings, I dont hit rush hour in either direction. So I wonder what to make of this?
Anyone has ideas on the correct rpm/gear change for a Linea 1.3 MJD?
I tried to reinstall and select Turkey, but I just cant seem to change country anymore.
Ok, I found out why I could not change Country. TO get multiple Country options, you need to go to the main fiat link (provided by OP), and select International English as your language.
Having done that, I tried multiple countries, Turkey, Greece, Italy etc. However I dont have any diesel choice except a 6 Speed 1.6 MJD.
Last edited by Rehaan : 14th October 2011 at 16:52. Reason: Please use the EDIT button to add to an existing post within 20 minutes instead of posting another consecutive post.
karthik_rao is offline   Reply With Quote
Old 14th October 2011, 17:59   #22
h14
h14's Avatar
Thanked: 1,720 Times
@Karthik, geeash has a Linea 1.4 FIRE and he is getting correct figures in ecoDrive. Even I had the same issues as I have Linea MJD. So currently I have switched off ecoDrive. Hope FIAT adds the 1.3MJD with 5speed to ecoDrive. One use of having it in the MJD is that it gives you correct readings for acceleration and deceleration to an extent.
h14 is offline   Reply With Quote
Old 26th March 2012, 01:25   #23
sandeepmohan's Avatar
Thanked: 1,898 Times
Got Eco Drive going on my ride. I have set up the car as a Linea 1.4 Petrol sold in the UK market.
ECO:Drive is working in Fiat Linea !!!-ecodrive2.jpg
ECO:Drive is working in Fiat Linea !!!-ecodrive3.jpg
sandeepmohan is offline   Reply With Quote
Old 26th March 2012, 10:01   #24
akshay4587's Avatar
Thanked: 1,686 Times
i got it running on my MJD as well,but the same problem of engine not available,it tells me that my gear shifts arent proper
Old 26th March 2012, 17:50   #25
drdeepudev's Avatar
Thanked: 54 Times
Hello Sandeepmohan and Akshay, I switched off the ecodrive option from the menu, the reason being the lack of our engine variant (1.3 mjd) in the menu. I believe those figures which we are getting might be wrong owing to this difference. Why can't fiat add this engine variant to the existing list. For petrol FIRE 1.4 owners it is a cool function.
drdeepudev is offline   Reply With Quote
Old 26th March 2012, 18:00   #26
akshay4587's Avatar
Even i have switched it off,Ecodrive was never created keeping india,lets hope that future versions have 1.3MJD engine as the option,Punto has the option of 1.3 90HP,i tried configuring using it,but it didnt work.
Old 26th March 2012, 18:25   #27
Awaiting Email Confirmation
Thanked: 4,225 Times
Ditto here for the following reason:
This was the maximum Eco Index that I got after many months of tracking and driving as advised by EcoDrive:
ECO:Drive is working in Fiat Linea !!!-ecodrive9311.png
The irony was that the above score was awarded to me for driving in congested bumper-to-bumper peak hour traffic in Bangalore. For driving in Bangalore, I used to get a minimum of 70. On the contrary, on the highways, my score used to be less than 70 even for moderate driving with optimum speed of 80 - 90 kmph as recommended by EcoDrive.
I had set a goal of 80 for myself, which I never got. So, I made EcoDrive to sleep.
J.Ravi is offline   Reply With Quote
Old 27th March 2012, 17:38   #28
justin.das's Avatar
Thanked: 70 Times
thread .
My car is Fiat Linea Emotion Pack 2009 model equipped with blue and me.The eco drive installation was successful and in the dash console its shows ecoDrive is on.but when i plugged a pendrive that data is not getting copied to the pendrive.The pendrive is empty while checking with pc.how can i fix this issue.When i contacted dealership they are unaware of ecodrive.
justin.das is offline   Reply With Quote
Old 28th March 2012, 14:15   #29
geeash's Avatar
Thanked: 132 Times
First download ecodrive for pc and install. Plug in your usb and prepare it for plugging in car.. It will create a folder called ifiat in it. Then plug it into the car
geeash is offline   (1) Thanks Reply With Quote
Old 29th March 2012, 14:42   #30
justin.das's Avatar
Thanked: 70 Times
Thanks geeash.successfully copied data to PC.but the problem is in ecodrive software it shows linea 1.6 ,105bhp with 6 gear transmission.
Tata Motors displays Iris Electric and Hybrid bus at FAME India Eco Drive Aditya Commercial Vehicles 1 27th November 2015 22:08
Eco Rent a Car introduces premium self-drive options (Q7, 5-Series, S-Class) S2!!! Street Experiences 2 19th September 2015 16:09
Santro Eco or Santro GL (Any Review/Comments Eco) ForeRunner Hatchbacks 4 11th December 2008 18:56
comparison of eco friendly cars... babe_on_wheels Technical Stuff 1 21st June 2006 14:20
toyota eco friendly car babe_on_wheels Technical Stuff 1 19th June 2006 19:34
