Old 23rd March 2011, 15:21   #16
Default Re: 3rd Gear Problem in Swift Vdi 2008
Attached are pictures on how to access and apply grease on the gear shift stick and the wound cabling.
kzaveri19 is offline   (1) Thanks Reply With Quote
Old 18th August 2013, 13:47   #17
arun_josie's Avatar
Thanked: 4,887 Times
I am facing similar gear issues which is discussed on this thread. Shifting 2nd to 3rd happens with a thud sound. But this is very intermittent, may be it happens once in a week. And I have observed this since i bought this car, initially the SA told this will go away by 10K Kms. But now its around 65K on the ODO but this issue still exists. I didn't take this issue seriously as well. Please advise on what should i look for. The gear/clutch assembly has not been touched till date.
Swift Dzire ZDI(2011 - Prev Gen)
ODO - 64250
arun_josie is offline   Reply With Quote
Old 20th September 2016, 12:19   #18
Thanked: 91 Times
My WagonR (Lxi Duo) developed some gear shifting problem yesterday. The gear doesnt slot into 3 gear when moving up from 2 gear. The problem is less when given a little shake / move to 4 (with clutch depressed of course) and then downshift.
Service center suspects a synchronizer problem and suggests a gear box overhaul. Any suggestions please?
(Car has done only 43K and it is too early to open gear box :( ).
babu.sundaram is offline   Reply With Quote
Swift 1.2 : 3rd Gear refuses to engage above 3k RPM sajo Technical Stuff 13 4th January 2012 13:08
Cruise in 3rd gear, or keep shifting between 3rd & 4th? syravi Technical Stuff 11 29th September 2011 10:44
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 85 2nd September 2009 18:47
Swift VDI or Getz GLX-6L Budget EDIT: Bought VDI agm Hatchbacks 29 11th April 2008 22:56
