Old 21st September 2009, 11:41   #16
rajiv.kulkarni's Avatar
Default Thanks, Problem solved
Its adequately powerful. Change the direction of nozzle using a pin to direct the war to center of the windscreen. If you just tap the water spray for a moment and dont keep it depressed wiper wont start. So you go tap tap, get some water on windscreen and then keep it pressed.
Hi, Thanks this helped me solve the issue on my Santro where the water was getting sprayed all over the car except the windshield .
Thanks,
Rajiv
rajiv.kulkarni is offline   Reply With Quote
wiper/washer synchronisation problem. pgsagar Technical Stuff 12 10th July 2010 19:41
Wiper problem in Santro subhojitb Technical Stuff 13 25th October 2008 07:59
Old Indica LEi / New Indica DLS / New Alto LXi shuvc Hatchbacks 20 19th February 2008 17:31
Indica Xeta LPG or Indica Turbo Diesel?? nobreaks Hatchbacks 12 1st September 2006 23:29
Indica Turbo or Indica Xeta BNB Hatchbacks 6 23rd April 2006 11:19
